Engine Popping Sound.
14 replies to this topic
#1 daenesh
daenesh
  • 423 posts
  • Local Club: Classic Car Owners Group
Posted 07 May 2014 - 06:15 AM
hey guys.. its been awhile since ive posted.. im driving a 998 A+ CLUBMAN with a stage 1 kit.. in other words i have a LCB, HS4 with AAU needle and uprated springs, K&N cone high air flow filter, high flow fuel pump, 8mm silicone spark plug cables, lucas gold sport coil and so on..
lately ive been having issues when i idle my car at any revs it will pop.. as in the exhaust makes a small pop pop pop sound like a misfire.. does anyone have any ideas as to whats causing it? thanks in advance :)
#2 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 07 May 2014 - 06:56 AM
have you re adjusted the mixture?
#3 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 07 May 2014 - 06:57 AM
also do you have ballast or un ballast ignition?
#4 daenesh
daenesh
  • 423 posts
Posted 07 May 2014 - 07:27 AM
I have readjusted the fuel mixture and even before I got the AAU needle It was causing the same problem.. So can't be the mixture.. Also I'm using a non ballasted coil 12v unit
#5 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 07 May 2014 - 07:41 AM
Best thing to do will be get it on a rolling road now you have had the stage 1 kit fitted.
#6 Alex_B
Alex_B
  • 4,573 posts
Posted 07 May 2014 - 09:02 AM
The popping is coming from a rich mixture continuing to combust in the exhaust (strictly speaking combustion happens in the exhaust anyway, but when the engine is running rich the combustion in the exhaust is much more severe and noticeable)
As mentioned, a rolling road will allow your engine to be mapped with its new components and a needle profiled to suit
#7 daenesh
daenesh
  • 423 posts
Posted 07 May 2014 - 09:20 AM
ive had this setup for years now and only now im having this problem.. so thats what im trying to say.. did a rolling road somewhere in January this year..
#8 Alex_B
Alex_B
  • 4,573 posts
Posted 07 May 2014 - 09:22 AM
Well I wouldnt worry too much then, is it possible you are only hearing the popping now the weathers warmer and your windows are open when driving around?
#9 daenesh
daenesh
  • 423 posts
Posted 07 May 2014 - 09:38 AM
i like in Malaysia.. weather is hot all year around.. so no this is not something ordinary..
#10 Alex_B
Alex_B
  • 4,573 posts
Posted 07 May 2014 - 09:40 AM
Ahh I didnt see that!
If you havent changed the fueling then chances are something has failed in the ignition system. But it is quite common for popping to happen on an engine that has been modified in the way yours has, mine pops quite readily but I do have a larger exhaust which highlights this.
Does the car run any differently? loss in performance or anything?
#11 daenesh
daenesh
  • 423 posts
Posted 07 May 2014 - 09:49 AM
i wouldn't say loss of power but rather not smooth idling.. so its rough when it idles.. when the pop happens you can see the revs drop by maybe 100rpm for a sec and return back to the orginal spot..
#12 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 07 May 2014 - 10:38 AM
You running a dizzy? timing could have slightly changed
#13 daenesh
daenesh
  • 423 posts
Posted 07 May 2014 - 10:46 AM
yeah running a 56D dizzy with points..
#14 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 07 May 2014 - 10:47 AM
Embrace it.  Pops and bangs are ace :D
#15 daenesh
daenesh
  • 423 posts
Posted 07 May 2014 - 10:49 AM
hahahaha i know but just hate the rough idling when im stuck in traffic..
