Posted 29 April 2014 - 06:49 PM
Need a new cam for my 998 currently has a 731 which isn't great so what would be best?
Current Spec is
998 block A+
12g295 had some work not sure what
Standard box
Hs4 k&n and MED
and the 731.
Cheers Jack
Posted 29 April 2014 - 06:52 PM
Posted 29 April 2014 - 06:54 PM
Posted 29 April 2014 - 07:59 PM
I had a 731 in a 998 and it was superb.
Not all of them were ground equal according to those in the know, so I may just have gotten lucky when I chucked it in dot-to-dot.
The MG Metro cam works very well in a 998.
Posted 29 April 2014 - 08:27 PM
Posted 29 April 2014 - 08:41 PM
Posted 29 April 2014 - 08:42 PM
Posted 30 April 2014 - 06:10 AM
The AC Dodd cams don't seem to be on the Guessworks website or am I missing something?
Posted 30 April 2014 - 06:33 AM
Posted 30 April 2014 - 08:44 AM
Posted 30 April 2014 - 09:44 AM
Posted 01 May 2014 - 12:01 AM
Hi
The SW5 cam is good but the ACDodd RS cam is everything the SW5 is and more, it's been much more cleverly designed rather than trial and error with different shape lobes, smooth as butter idle and will pull hard from very load down
well having fitted both SW5 and ACDodd RT1 to the same motor
I would say they are very much the same
so the ACDood RS cam should be even better
Mini Technical Sections →
Problems, Questions and Technical →
Low Compression Across The BoardStarted by Vinay-RS , 11 Nov 2024 engine |
Clutch Parts And FittingStarted by Apeman85 , 10 Nov 2024 engine |
1980 998Cc Engine - Can Someone Willing To Learn Strip And Rebuild An Engine?Started by LukeClassicMan , 04 Nov 2024 engine |
Answered
Low Oil Pressure On Fresh RebuildStarted by sgallegly , 29 Oct 2024 engine |
1995 Spi Clutch Not Disengaging After ReplacementStarted by David12 , 26 Oct 2024 engine |
