FRONT ENGINE R 1 REAR WHEEL DRIVE
#16
Posted 14 June 2006 - 05:59 PM
#17
Posted 14 June 2006 - 06:03 PM
#18
Posted 14 June 2006 - 06:12 PM
ther shoud be room for the diff if the wheels just spin ill have to put a couple of slabs in the boot LOLYou will probably need more than the weight of a fuel tank and a battery to give you good traction. You will want most of the weight over the rear wheels. Also, i dont think you can keep the rear seats, that's where the diff will be
thanks for the photo mate what diff is it and what engines in the frontplenty of room for the diff
#19
#20
Posted 14 June 2006 - 06:17 PM
The floor is modified slightly insidethe rear arches to accommodate the suspension towers but this would only take up minimal space in the boot of a saloon
That's an estate, 4" extra wheelbase, not sure about a saloon....
It's a pick-up, but the same rules apply. Would a saloon have a tendancy to swap ends at high speed??? It's a risk.
#21
Posted 14 June 2006 - 07:56 PM
#22
Posted 14 June 2006 - 09:10 PM
any chance you could out them on for us cheersBy the way, it has been done before, i have some pics on my other pc
#23
Posted 14 June 2006 - 09:56 PM
yes i want to keep the rear seats as ive got 2 small boys who like the mini shows they are 3 and 5 they love minis so they got to stayThe fisher fury is bike up front to rwd, but I think they use a sierra type 9 gearbox to do it, as does allspeeds xe conversion to rwd. However this box is mahoosive and would require alot of bulkhead and floor mods to get it in.
I'm guessing the point of front mounted and rwd is because you want to retain the rear seats?
#24
Posted 14 June 2006 - 10:28 PM
[/quote]
It is the whole running gear from a Honda Civic Shuttle 1.6 16v 4x4. It is a worthy consideration as it has 6 speed box and permanent 4wd!
The diff might be of use to you. but for bike engine purposes I think you'd be better off sticking to T5 / t9 ford box as all the required conversion items will be readily available from the kit car manufacturers.
I reckon then that sticking to the diff soloutions that they use is also a logical step.
