FRONT ENGINE R 1 REAR WHEEL DRIVE
23 replies to this topic
#1 ANDY J
ANDY J
  • 303 posts
Posted 14 June 2006 - 08:55 AM
I WANT TO PUT A R 1 ENGINE IT THE FRONT OF MY MINI CONVERTABLE BUT HAVE IT REAR WHEEL DRIVR
IS THERE ANYONE OUT THERE THAT HAS KNOWN OF THIS DONE AND HAS ANYONE GOT ANY IDEAS
YES I KNOW YOU CAN GET THE KIT FROM Z CARS BUT THATS THE BORING WAY TO GO
ANYWAY I GOT 2 LITTLE BOYS THAT LIKE GOING TO THE SHOWS WITH DADDY AND SEE ALL THE GOOD MINIS OUT THERE AND IM NOT GOING TO DISAPOINT THEM SO I WILL DO IT ONE WAY OR THE OTHER
PLEASE SOMEONE HELP :lol: :) :P
#2 miniboo
miniboo
    Lord of Original Thinking
  • 9,327 posts
Posted 14 June 2006 - 09:42 AM
Smudger is doing a front engine fronty wheel drive.
i dunno if you would be able to use an r1 engine for rear wheel drive though. Might need to use an engine that is prop driven.
#3 dan__wright
dan__wright
  • 322 posts
Posted 14 June 2006 - 09:53 AM
could be done, if you mount the engine transverse and connect it to a propshaft, the a diff at the back to drive the wheels, as a bike only has one output that should make things easier but not 100% on how you would couple the box to the prop
#4 Steamo
Steamo
  • 377 posts
Posted 14 June 2006 - 10:29 AM
I know of a buggy racing place that uses bike engines transversly mounted with the drive flange from the sprocket mated directly to the flange on a cossie rear diff (umm flange to flange! - gotta get in there before jammy :lol: )
The buggies use a mid mounted confiuration but I don't see why you couldn't put a prop in between the flanges and run the engine in the front. Only thing that might be a worry is the gear ratios - but I'm sure it'd be possible to get the diff altered.
Worth a thought and I thoughly recommend trying the buggy racing if you're anywhere near notts/mansfield area!! Makes a brilliant alternative to karting.
#5 Wil_h
Wil_h
  • 3,244 posts
Posted 14 June 2006 - 11:36 AM
Just look at all the westfield/cateram/locusts etc. that have rear drive with a bike power plant. that's where you want to start looking.
#6 minipip
minipip
  • 1,591 posts
  • Local Club: TMF SE
Posted 14 June 2006 - 04:46 PM
dont forget under their bonnet is big enuf to lie in. take it ur up for a little extencion on the front?
#7 pikey7
pikey7
  • 3,824 posts
Posted 14 June 2006 - 04:49 PM
true, but the powerplant isn't exactly huge......
#8 The Matt
The Matt
  • 17,231 posts
  • Name: Matt
Posted 14 June 2006 - 05:25 PM
yep, as said above I'd look at kit car mags.
I wonder if they use something like an Atlas gearbox, or if they retain the motorbike one. I guess they retain the motorbike 'box and just have a chain driven propshaft, with a traditional differential at the rear????
I know a guy who has a fireblade powered one (well, a guy I know, knows the guy with one). I wonder if I could try and have a look at it?
#9 ANDY J
ANDY J
  • 303 posts
Posted 14 June 2006 - 05:33 PM
:P yes your on the right track, thats what i got in mind but the only thing is trying to find the conversion sprocket to go from the bike engine to the prop, ive got a prop lined up thats only 1 & a half inches in diam 2 piece got to get the diff and the set on fitting it all might even have a go about a turbo R 1
THANKS FOR THE REPLY :)
:lol: yes i know they use the bike engine gearbox and there's an a adapter that they use but still trying to find 1
#10 The Matt
The Matt
  • 17,231 posts
  • Name: Matt
Posted 14 June 2006 - 05:34 PM
You could always get something CNC machined to suit the sprocket? I'll try and have a look at that blade powered one soon! :lol:
#11 Leonard
Leonard
  • 784 posts
  • Local Club: mini rebels
Posted 14 June 2006 - 05:38 PM
theres a front engined r1 mini on the ultimate mini madness dvd. i cant remember if its front or rear wheel drive though
#12 ANDY J
ANDY J
  • 303 posts
Posted 14 June 2006 - 05:43 PM
You could always get something CNC machined to suit the sprocket? I'll try and have a look at that blade powered one soon! :)
cheers mate i was told that there is someone on eBay that does them but still looking i'm trying to get everything together while I'm rebuilding the misses mini . then mine will be full steam ahead get it done as soon as poss but without cutting any corners i got to make the wheel base wider aswell so i can fit some BIG wheels thanks again :lol:
#13 R1minimagic
R1minimagic
  • 4,660 posts
I dont think there would be much point having front engine RWD, the back wheels would be spinning all the time due to the lack of weight over them. My rear wheels will spin quite easily if i want them to and that is with a lot more weight on them.....
The yellow one on the dvd is front wheel drive which is much better way to go if you want the engine in the front.
#14 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 14 June 2006 - 05:45 PM
The fisher fury is bike up front to rwd, but I think they use a sierra type 9 gearbox to do it, as does allspeeds xe conversion to rwd. However this box is mahoosive and would require alot of bulkhead and floor mods to get it in.
I'm guessing the point of front mounted and rwd is because you want to retain the rear seats?
#15 ANDY J
ANDY J
  • 303 posts
Posted 14 June 2006 - 05:52 PM
i didn't want front wheel drive i like the idea of rear drive because its different if the engine is in the front and i don't think its been done in a mini i hope
you've got a point but Ive thought of that the fuel tank is going in the back along with the battery ill be fitting much bigger wheels and wider 1s and ill be keeping the rear seats so ill not be losing that much plus I'm having a carbon front with the alloy doors and poly glass so if everything goes to plan it should balance it self out as it should be really light
