Engine/gearbox gaskets
8 replies to this topic
#1 adam c
adam c
  • 466 posts
Posted 27 June 2004 - 04:37 PM
Just wondering if any one knows what I should use as gasket sealent on the gasket between my engine and gearbox. It says about sealing it in my haynes manual but what should I use?? Also what should I use on the C-shaped crank oil seal thing, it mentions some sort of sealent, any ideas?? I'd give more detail but I don't have the manual handy because my home computers died :erm:
Any other tips for bolting it back together would be appreciated. Thanks....
#2 bluebottle
bluebottle
  • 844 posts
Posted 27 June 2004 - 04:44 PM
i use a non hardening gasket sealant, like blue hylomar, you only need a light smeer.
#3 P91MER
P91MER
    Ring Runner 2005
  • 829 posts
Posted 27 June 2004 - 08:06 PM
You can get full bottom end gasket sets for the mini, i bought one for a 1275 i had lying round.. comes with every gasket for the engine, gearbox, clutch all of em!!
Rich
#4 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 27 June 2004 - 11:51 PM
Over here there are two Permatex products commonly used, Permatex-2B and Aviation Form-a-Gasket. Form a gasket is thinner and brushes on, 2B is a paste in a tube but they are basically the same. Great for everything but alcohol.
On the front bearing cap seal I cheated. I used Blue RTV silicone to attach the seal to the gearbox before mating it with the block. I "glued" the seal in place and once that set, I put a smear of Form-a-Gasket on the top surface prior to putting the tranny back on the block. It's only been together for about 1000 miles but there are no leaks so far.
#5 adam c
adam c
  • 466 posts
Posted 29 June 2004 - 07:15 AM
Cheers..I have the full gasket set, just wanted to make sure I could just use the same gasket goo on the oil seal as on the gasket.
Thanks :grin:
#6 andyps
andyps
  • 132 posts
Posted 29 June 2004 - 07:26 PM
I put one together at the weekend and used blue hylomar - not got it in the car yet so still got my fingers crossed it is oil tight. I have done before and it was ok.
I am worried about a leak as one of the bolts sheared when was tightening it - no way to get the stud out without dismantling everything again and frankly I couldn't be bothered, plus I would need new gaskets again :sad:
#7 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
  • Local Club: Blacktop Bombers
Posted 29 June 2004 - 08:06 PM
I use Hylomar Blue on my engines and havn't had any probs with it. I took a Mini Sport engine apart once and it didnt have any gasket paste on it at all, and it didnt leak anywere! You gotta be pretty confident to do that tho I recon!!
#8 bluebottle
bluebottle
  • 844 posts
Posted 30 June 2004 - 10:01 AM
some vintage engines, bugatti i think, are built to such tolerances that they dont use gaskets!
#9 Pavel
Pavel
  • 2,451 posts
Posted 30 June 2004 - 03:04 PM
Yep, many racing cars don't use head gaskets either, but the surfaces have to be *PERFECT* for that to work!
