Wtf, now im pissed
24 replies to this topic
#16 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 15 June 2006 - 04:19 PM
Good point about the bulkhead. If multiple brown wires melted (as you implied earlier) be sure to follow their paths away from the fuse box looking for where they may have become grounded and don't forget to check adjacent wires if the brown wires were inside the loom.
#17 Clayman
Clayman
  • 80 posts
Posted 18 June 2006 - 09:27 PM
Hi Dklawson! Thanks for the help, i feel like im learning something now. But how does one brown wire supply power to all the connections on the fusebox?
I had a look at the damage, i think the 2 brown wires are just melted at the fuse box connections. BUT theres a wire with an inline fuse that has totally melted away, melting most of the wires going through the bulkhead also :lol:
Its a wire that comes from the right, I think they run to the back of the car? Not sure, i will have to take out the dash board tomorrow and trace where it goes to.
#18 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 18 June 2006 - 09:42 PM
brown wires dont just surply the fuse box the travel else where too like to ing switch and headlamp switch etc, but brown wires are pem 12v and also got hazzards inline fuse. but if they have melted around fuse box then i will restate i think the fuse box has earthed out on bulkhead
dave
#19 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 19 June 2006 - 12:04 PM
Again, I don't have a wiring diagram for your car and you need to get one and study it. Minidaves has explained where the brown wires (permanently hot) go and given you some places to look for shorts. Take his advice and a wiring diagram for your car and I'm sure you'll be able to find the problem. If you don't already own one, this would be a good time and excuse to buy a volt-ohm meter to track down this problem.
#20 Clayman
Clayman
  • 80 posts
Posted 19 June 2006 - 03:18 PM
There was a pad of rubber behind the fuse box, could it have grounded from the screw holding the fusebox?
I have a volt meter, but i dont know where to start with one, i dont even know how to work the damn thing.. its so old. Maybe it is time for a new one.
#21 Clayman
Clayman
  • 80 posts
Posted 20 June 2006 - 04:04 PM
I had a further look. The one thats messed up my entire loom is this little blue wire that runs down below the heater, then up to the ignition. I think it stopped melting at this connector block (?). I really need help with this, im useless with electrics, and now i hate my mini :(
#22 pikey7
pikey7
  • 3,824 posts
Posted 20 June 2006 - 04:10 PM
can you snap us a pic of the loom so we can assess the damage and make a reccomendation?
#23 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 20 June 2006 - 04:35 PM
Pictures would help a lot.
Have you gotten hold of a wiring diagram yet?
Blue wires... well, the main headlight feed to the dimmer switch should be blue but that wire shouldn't be "little".
#24 Clayman
Clayman
  • 80 posts
Posted 20 June 2006 - 05:53 PM
I'll try get some pictures, Its blowing a gale outside and pissing down so it might be tomorrow.. nah i aint got anything better to do. Tonight i if find the camera!
Well when i say little, its the usual size :D
Sorry, my haynes doesnt have my model :(
Anyway, i'll get them pictures
#25 Clayman
Clayman
  • 80 posts
Posted 20 June 2006 - 06:18 PM
Battery is dead in the camera. Tomorrow Will be the day!
