get really thin aluminium or stainless steel disks as they cut thinner, which makes it cut quicker and therefore, a pack of disks lasts a bit longer
Cutting discs- how long should they last?
OllyD
, Jun 13 2006 06:22 PM
17 replies to this topic
#16
Posted 14 June 2006 - 06:30 PM
#17
Posted 14 June 2006 - 06:44 PM
Also try and ensure you cut the right way one way the grinder almost pulls its self along
NO.
DO NOT use a grinder this way, you must push the blade into the material you are cutting rather than cut with the blade rotation. Same with a router, circular saw or any cutting tool. It is very, very dangerous to cut with the rotation of the blade. For one thing the grinder can pull out of your hands and propel itself away from you. If you are doing it right and not forcing it then it will produce a good quality cut, without maiming anyone.
Edited by Dan, 14 June 2006 - 06:45 PM.
#18
Posted 15 June 2006 - 07:59 AM
NO.
Cheers for the advice Dan - just done my whole car this way - OOPS (lots of grinding to do on my camper though so cheers)
Oh well at least I know now. Sorry for the shoddy advice!
