Oil Filter Housing
8 replies to this topic
#1 minilee94
minilee94
  • 3,523 posts
Posted 25 April 2014 - 03:55 PM
Is it me or is the hole that the hose or pipe goes into on this housing is bigger
Is the one above bigger hole than this one
I have an spi block and ATM I have the filter housing ( bottom picture ) but the oil cooler braided hose don't fit it
#2 minilee94
minilee94
  • 3,523 posts
Posted 25 April 2014 - 04:49 PM
This is the hose I have both hose ends are the same size
#3 The Principal
The Principal
  • 763 posts
Posted 25 April 2014 - 05:06 PM
The lower housing looks like an older type with the tapered thread, think thats 1/4"NPT.
Edited by The Principal, 25 April 2014 - 05:07 PM.
#4 minilee94
minilee94
  • 3,523 posts
Posted 25 April 2014 - 06:29 PM
Yeah that the one I have now and the cooler hose don't fit
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 25 April 2014 - 06:30 PM
The filter heads on the later 1275 engine ( last of the carbs and SPi ), ie those fitted with the compression fit pipe, are different to the previous ones which use the pipe with the banjo joint on the block.
#6 minilee94
minilee94
  • 3,523 posts
Posted 25 April 2014 - 06:39 PM
Okay so I take it the pic at the top is the one with a bigger hole for pipe
Also I can find adaptor to go to my hose to my filter head wich is the lower pic
#7 minilee94
minilee94
  • 3,523 posts
Posted 25 April 2014 - 06:54 PM
Also a quick one who knows the hose thread the end that goes onto the cooler
#8 The Principal
The Principal
  • 763 posts
Posted 25 April 2014 - 06:55 PM
not my area of expertise but this may be the kiddie - http://www.minispare...px|Back to shop
#9 minilee94
minilee94
  • 3,523 posts
Posted 25 April 2014 - 06:57 PM
Nah isn't that as the end of the hose is male threaded not female
Upper pic is the end of the hose
Cheers anyway
