Wilwood Calipers
Posted 22 April 2014 - 09:49 PM
I have the kit on my mini but I've lost the box the calipers came in. I'm trying to find the caliper specs to see if I can use them on another project.
Tom
Posted 23 April 2014 - 09:11 AM
Posted 23 April 2014 - 10:34 AM
Part numbers are on this page - unsure of piston area though (if you have some maybe remove the pad and measure the piston size to confirm:
http://www.wilwood.c...bname=Powerlite
Posted 06 May 2014 - 04:05 AM
Hey Kirk,
Somewhat related to this post... When I was looking at the Wilwood website and then talking to ZCars about the big brake kit and pedal box setup, I was told the master cylinder sizes they suggest/supply for both front and rear are the 0.750 cylinders... But I couldn't help but notice that yours are the 0.625 cylinders.
Just wondering why that was?? Like if that's just what you ended up with by chance? Or if that was a conscious decision you made to go for the smaller cylinders... And if so, what the reason was and what the benefits are, etc??
Thanks,
JEFF
Posted 09 May 2014 - 06:51 AM
Jeff, as per my PM message reply to you and for others reading I am using 0.75's now as the 0.625's are not big enough for the Powerlites.
Posted 12 May 2014 - 09:51 AM
Hey Kirk,
Thanks,
JEFF
with the ratio of the mini pedal using 0.75 gives better feel for the brakes
