Is Filler Really That Bad?
23 replies to this topic
#16 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 22 April 2014 - 11:46 PM
9/10 dents can be taken out by a skilled panel beater.  9/10 bodyshops arent skilled in doing this though sadly.  Hence the filler being used instead.
It's not so much about lack of skill, It just depends on the type of bodyshop.
The Vauxhall main dealer bodyshop that i worked at for 8 years used filler but only to finish. We simply were not allowed to spend the time required to repair without it. the problem is, we all had to work to a very fast paced schedule and the time involved in bare metal repairs would have put us behind and we wouldn't make the bonus.
Sounds bad i know but by no means was anything bodged, Dents were planished  out to a good standard and any slight high spots or imperfections were filed 'true' with a body file. Then a light skim of filler or 2k stopper would be used to accurately restore  the shape of the panel or swage lines to 100%. It is the only way to get a perfect repair in the time allowed.
Mind you, the cars we worked on all day every day were either new or nearly new so anything more than a slight dent or scrape would often result in panel replacement anyway.
If it was an older car (8-10 years old) then in order to make the repairs economical in order for the insurance to pay rather than write off, time allowances would be cut down and repairs would be quoted instead of panel replacement. In those cases then filler would defiantly be used.
At the end of the day who in their right mind would work on a repair for longer than they are being paid to do so? as long as the finished result is good and it doesn't have huge thick chunks of filler in it, everybody is happy!
As for private body shops, then it is between them and their customer to agree how much the job is going to cost and if they quoted for bare metal 'proper repairs' then the bill would be alot higher due to time involved and most would opt for a lower bill and a light skim of filler.
It all depends on what is reasonably worth doing i suppose.
Ben
#17 Pauly
Pauly
  • 4,213 posts
Posted 23 April 2014 - 08:08 PM
Is there a need to fill such a large area on a panel? I've always ever filled in small areas only where the dent is, but most filler work I see done in bodyshops tend to cover a large area?
Edited by Pauly, 23 April 2014 - 08:08 PM.
#18 Alex_B
Alex_B
  • 4,573 posts
Posted 23 April 2014 - 09:05 PM
If the panel is warped but only slightly then yes a skim of filler over a large area can be used to even the surface, if not it would be very difficult to modify the panel without any filler
#19 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 23 April 2014 - 09:06 PM
Yes sometimes it is better to give the full panel a light skim, this is usually done after the low spots have been taken care of a final skim perfects the panel.
#20 Carlos W
Carlos W
  • 10,114 posts
Posted 23 April 2014 - 09:09 PM
I put too much on then spend my whole life taking 95% of it back off
#21 Rocket.
Rocket.
  • 1,441 posts
Posted 23 April 2014 - 09:10 PM
I also do this I've never been any good at body work prep
#22 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 April 2014 - 09:23 PM
Its all in the angle of the dangle.
Hold the spreader at quite a tight angle with only light to moderate pressure. If you use the large spreaders that come with the tin, use the side of the spreader, you get better control.
avoid using spreaders with handles or putty knives as they are difficult to control.
If you have a small dent, then it is good practice to spread the filler over a larger area as this allows for the filler to be feathered in nicely and usually avoids the need for another layer.
oh and never put filer over paint, especially thick paint!
#23 Carlos W
Carlos W
  • 10,114 posts
Posted 23 April 2014 - 09:27 PM
See you Saturday!
I'm sure I've got a bit of filling that needs doing
#24 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 23 April 2014 - 09:29 PM
Rite o  ;D
