How I Made An Led Interior Light Work
electrical
5 replies to this topic
#1 Classic1275cc
Classic1275cc
  • 417 posts
  • Local Club: south lincs mini club
Posted 22 April 2014 - 07:46 PM
when i posted a question about why my LED interior light wouldn't work i got allot of replies so i thought it would be worth while posting my solution :)
the problem was the led bulb will only light up when current passes through them correctly, unfortunately the carrier is set up a bit backward for led bulbs :L
useing standard clips and a bit of fileing i redirected the earth
the clips are ideal because they insulate the old tab from contacting the positive point on the bulb, but one side the plastic needs cutting of to make more room when the bulbs in
then i souldered a wire to the positive tip of the bulb, with a male clip on teh end for the cars positive feed to plug into
popped the bulb in and presto, crisp white light for my mini :D
hope seeing this helps people out :)
#2 Richie83
Richie83
  • 1,495 posts
Posted 22 April 2014 - 07:48 PM
Great little tip. Thanks a lot. Where did you get the bulb?
#3 Classic1275cc
Classic1275cc
  • 417 posts
Posted 22 April 2014 - 07:58 PM
i got a pair of an ebay man,
http://www.ebay.co.u...009&rk=1&rkt=4
these look identical but are not from the same seller anymore
there are so so many to choose from, types and sizes ect, but these fit and I'm happy with their performance
#4 MiniElliott
MiniElliott
  • 378 posts
Posted 22 April 2014 - 08:57 PM
Would it not have been simpler just to switch the positive and negative wires running to the housing ?
#5 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 22 April 2014 - 08:59 PM
looks good, have you got a picture of it lit up in the mini?
#6 Classic1275cc
Classic1275cc
  • 417 posts
Posted 23 April 2014 - 05:09 PM
i had it like that for a bit but i had to turn the light on manualy because the door switches wouldent turn it on like that :(
