Earthing Strap And Starter Motor
Best Answer Stevie W , 19 April 2014 - 08:18 PM
Hi again!
Having the correct starter to match the ring gear on the flywheel should stop the starter motor jamming on the ring gear and should give you a good improvement on spinning over the engine!
Others will be more qualified giving you advice on wiring up this type of starter motor if you have the inertia starter wiring, but is is possible!!
As others have said, make sure there is a good earth lead running from the engine (bolting it to the starter motor mounting bolt will give a good connection) to the body of the car, then you should be ok!!
Cheers, Steve.
Go to the full post
#16
Posted 23 April 2014 - 05:01 PM
