Puff Of White Smoke On Startup
33 replies to this topic
#16 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 18 April 2014 - 06:41 PM
Also, it's not brake fluid. Don't let whoever said that ever work on your Mini.. Haha :-)
Well im new to this haha i can only by what im told lol
#17 sledgehammer
sledgehammer
  • 3,098 posts
Posted 18 April 2014 - 07:46 PM
It is a possibility - so you are correct in what you said - but it is rare - it will get a bit more common as servo cars get older
on some cars it's possible for ATF  fluid to be sucked into the engine (auto's) giving smoke (can't remember what colour)
#18 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 18 April 2014 - 07:47 PM
That makes a change that im almost right about something :)
#19 sledgehammer
sledgehammer
  • 3,098 posts
Posted 18 April 2014 - 07:54 PM
haha, how does the brake fluid get into the engine?
The brake fluid is drawn from the master cylinder outer seal thru the servo into the servo pipe , into the  inlet manifold
takes a few worn seals - but not impossible , seen a few cars with it over the years
I doubt it will be seen on a new car - but you never know
have seen an old merc do it - drained the reserve , & fouled 2 plugs
took a lot of head scratching to work it out ,
#20 benbrown
benbrown
  • 18 posts
Posted 18 April 2014 - 09:11 PM
Without hijacking the thread....
What could be the cause for smoke when revs go higher? I had to out my foot down to avoid a truck and a large puff of bluey white smoke came out with it, is this normal?
#21 sledgehammer
sledgehammer
  • 3,098 posts
Posted 18 April 2014 - 09:37 PM
not so good - usually indicates rings / pistons worn
but also worth looking at the breathers & pipes not crushed , valve stem seals / guides ,
oil condition as well
how many miles & what spec engine ?
#22 benbrown
benbrown
  • 18 posts
Posted 18 April 2014 - 09:44 PM
99k miles, 1275, it's been sat for a while. Previous owner serviced it before he sold it, I checked the oil and it's very clean!
I'll have a good look at that tomorrow. Just wondered whether to be worried! The manifold has a crack which is being replaced, didn't know if that was a factor?
#23 Dusky
Dusky
  • 5,322 posts
Posted 19 April 2014 - 01:54 PM
i was on a mini run and another mini was kicking out white smoke when it started and break heavily apparently the engine sucks break fluid into the engine and burns it has your break fluid gone down at all?
This is the best post on TMF ever!  :lol:
Given the fact that its possible, your reaction is even better ;)
#24 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 19 April 2014 - 03:43 PM
But yet.....I still dont care! :lol:
Extremely unlikely
#25 turbominicooper
turbominicooper
  • 295 posts
Posted 19 April 2014 - 03:56 PM
might be able to out this to bed.
after posting on here yesterday i did some tweaking with timing and mixture
just fired her up and no puff smoke??
ill give it another blast tomo and if none then can safely say it was down to one of these
#26 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 19 April 2014 - 04:30 PM
That wouldn't cause white smoke, black smoke perhaps as a result of over fuelling.
#27 turbominicooper
turbominicooper
  • 295 posts
Posted 19 April 2014 - 05:37 PM
just letting u know what happened
#28 HarrysMini
HarrysMini
  • 3,352 posts
Posted 19 April 2014 - 05:48 PM
White smoke will only usually appear when it's cold (outside and engine). If it does then that it normal and just condensation. If it's happening when it is warm outside then there is something else.
I can't think of the other causes for white smoke, I'm sure someone else will confirm.
#29 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 19 April 2014 - 05:58 PM
HG failure and coolant will cause white smoke.
#30 turbominicooper
turbominicooper
  • 295 posts
Posted 11 May 2014 - 09:52 PM
NA no turbo.
i will get a vid tomo morning and post up for clarification
not quite tomo morning but heres the vid:
its strange cause when the timing is advanced this puff of smoke does not occur its only when i retard it to a safe timing i get this??
