as mentioned in title.
turn the key and big puff of white smoke comes out then clears shortly.
ideas?
Posted 18 April 2014 - 11:30 AM
ideas?
Posted 18 April 2014 - 11:42 AM
i got told white smoke was break fluid have you got servo breaks?
Posted 18 April 2014 - 11:55 AM
i have but never heard that theory before...
Posted 18 April 2014 - 11:59 AM
i was on a mini run and another mini was kicking out white smoke when it started and break heavily apparently the engine sucks break fluid into the engine and burns it has your break fluid gone down at all?
Posted 18 April 2014 - 12:05 PM
haha, how does the brake fluid get into the engine?
Posted 18 April 2014 - 12:24 PM
Posted 18 April 2014 - 12:25 PM
Posted 18 April 2014 - 12:32 PM
This is the best post on TMF ever!
Posted 18 April 2014 - 01:00 PM
It's common, probably just the condensation burning off the exhaust/engine. Pretty much every car we own does it when cold. Very normal.
Does it happen just when cold or when hot as well?
just on first startup
Posted 18 April 2014 - 01:02 PM
Posted 18 April 2014 - 01:16 PM
probably condensation / steam on start up
could be light blue smoke - in which case could be valve guide seal , which harden over time , & let a bit of oil drain down while engine off
if its valve guide seals - I wouldn't worry too much if it is only on start up - also gives the valve stems a bit of lube which won't hurt
also the servo can draw brake fluid thru a leaking master cyl , and it can get ingested in the engine - rare but it happens -
usually on 2 cylinders , fluid level will drop sometimes suddenly (may cause miss-fire - not always)
very dangerous , can cause brake failure
http://www.v8registe...s/V8NOTE228.htm
the above if from a MG page - but same applies to servo-ed mini's
if the servo is suspect - don't drive it
Edited by sledgehammer, 18 April 2014 - 01:23 PM.
Posted 18 April 2014 - 01:34 PM
If your motor has a brake servo disconnect the hose that goes to the inlet manifold and plug it on the inlet manifold side. then give it a try see if the smoke stops. Not totally inconceivable, though I have never heard of the issue before. Brake fluid getting past a worn seal in the servo and getting into the vacuum pipe to the inlet manifold will get sucked into the engine and thus burned. If this is what is happening the inside of the hose will be contaminated with brake fluid.
Edited by Stu1961, 18 April 2014 - 02:35 PM.
Posted 18 April 2014 - 02:31 PM
Good article that
Posted 18 April 2014 - 02:55 PM
What engine are we talking about here, is it a turbo or normally aspirated???
Condensation on a cold morning / day is normal but should clear quickly. If it persists then it could be coolant which will point to a HG issue.
Blue smoke on start up points to valve seals / worn guides but again should clear up. Continuous blue smoke will be worn rings / bores.
If you have a turbo and depending on the type, blue smoke on start up could be worn bearing seals. Also noticeable when giving the car beans. See a few of these over the years and will require a turbo rebuild.
As to brake fluid being sucked into the car via the servo this could be a possibility.
Posted 18 April 2014 - 04:22 PM
NA no turbo.
i will get a vid tomo morning and post up for clarification
