Using Old Engine Oil To Prevent Rust
Posted 17 April 2014 - 06:03 PM
Posted 17 April 2014 - 06:11 PM
It won't harm it, certainly a good thing to do until you can afford proper products (use Bilt Hamber stuff)
We've filled the chassis box sections on our Land Rover with old engine/gear/diff oil, in fact whenever we do an oil change on any of our cars, the oil goes in there to save trying to find somewhere to dispose of it.
Posted 17 April 2014 - 06:15 PM
It'll drip off and cause pollution
Posted 17 April 2014 - 06:20 PM
The biggest problem other than it being nasty to not only you but to the enviroment is cleaning it off before you apply waxoyl etc.
Posted 17 April 2014 - 06:39 PM
Posted 17 April 2014 - 08:43 PM
These days you would be very lucky to avoid arrest for causing pollution. Used engine oil is very dangerous indeed, with heavy metals (which is why it does preserve garden sheds rather well) and numerous carcinogens, so it must, in no circumstances, get near people or the drainage system. It also has a high acid content, due to contamination by piston blow-by, and in some circumstances will accelerate corrosion.
My advice is, don't even think about using it on the underside of your car. Take it to your local council dump for safe disposal. It gets, or should be, recycled back through an oil refinery, which is very good for the environment.
Posted 17 April 2014 - 08:53 PM
I would think the vehicle would already have to be on fire, and fairly hot to make the oil ignite but it'll certainly make the fire brigades job more difficult in the event of a fire.
Posted 17 April 2014 - 09:43 PM
I'm working on a mini van at the moment that had been covered in oil even its rear load bed inside the van didn't get missed,
Althou I would say it seems to of protected the van from the elements I wouldn't think about using it myself its a mess and gets everywhere, I was sick and tired of getting it on me and the constant smell of oil isn't the best of aromas, Its also been a total pig to get off,
I would take the above advice and steer clear of using old oil,
The weather is starting to warm up and so its not like it needs to be done straight away, Save over the next few weeks and do it properly you will be more pleased with yourself with a job well done
Posted 18 April 2014 - 07:18 AM
I did it on my 1st mini and it worked a treat.
Posted 18 April 2014 - 08:59 AM
my old mini's floor was covered in oil anyway ( from oil leaks ) ! but the floor was totally solid when the rest of the car was dissolving ! so take from that what you like
Posted 18 April 2014 - 09:55 AM
quote ' These days you would be very lucky to avoid arrest for causing pollution '
for putting engine oil on a floor pan / sills
I must be very lucky
most mini owners must be in the slammer for the oil leaks ,
you may get a warning / told to get the oil leak fixed if its bad - but arrest - nah
I've been doing it for years - so did my dad / grandad
Edited by sledgehammer, 18 April 2014 - 01:02 PM.
Posted 18 April 2014 - 02:58 PM
I think what we can agree on this has being going on for years and was common practise. But if you want to put anything else on the car then all of this will need to thoroughly cleaned off otherwise you will never get the product you want to use to stay on.
As for being arrested well good luck with that.
Posted 18 April 2014 - 04:20 PM
I think ultimately it is up to you what you put on the underside of your car. You can either splash some old oil on the underside and that will protect it very well (My Dad's early 50s Minor has been oiled every year from new and is still in excellent condition), however you risk being arrested , or you could spend £20-40 and get the proper stuff.
What you could do is mix engine oil 50/50 with Waxoyl to make twice as much, which will make it more economical.
All I will say is that there is a reason why rotten front subframes are quite rare on Minis.
Posted 18 April 2014 - 04:46 PM
