Turns over but wont start MPI
Posted 12 June 2006 - 11:29 AM
Has fuel pressure, oil pressure, battery feed but no spark.
Checked all the sensors etc any ideas?
please help.
Dev
Posted 12 June 2006 - 11:42 AM
switch ignition on and open the boot you should hear it..
if not open the bonnet and on the right hand side at the very back is a button under a rubber cover, press it to make sure that the inertia sensor has not tripped.. if it clicks then it tripped and should start.
if not that open the fuse box (under dash beside drivers door) and look at the fuel injection system fuse..
i think it is 4th row down on the left.. 10 amp..
tells you on the cover..
make sure that has not blown.
if fuel system is working you need to check for a spark...
Posted 12 June 2006 - 11:57 AM
The coil pack has a 12v feed - Checked with meter.
It would appear thet the timing system is not telling the coil pack to fire. Held plug against block and no spark when turning the engine over.
It's maybe the crank sensor on the flywheel housing - Dave, it might be worth removing it and cleaning up just in case. Also, the blue connector on the bracket above the starter, check the resistance figure - Can't remember what Mr Green Flag said it should be though !!
I'm thinking that maybe something did not like being disturbed...
Posted 12 June 2006 - 12:00 PM
when you take a plug out you get the mist of fuel but no spark from the plug.
there is a feed going to the coil but no spark
was it 1600 ohms??
Posted 12 June 2006 - 12:01 PM
Posted 12 June 2006 - 12:34 PM
Posted 12 June 2006 - 02:51 PM
Not sure how common these are to pack in though..
I will have a look in the trusty book tonight and see what other things to check .
Posted 12 June 2006 - 05:07 PM
ta
oh msn is [email protected] text is #*#*#*#*#*#
Edited by Dan, 12 June 2006 - 06:39 PM.
Posted 12 June 2006 - 06:38 PM
I've removed your number but many people will have seen it by now and it may be cached by Google so you might well get a lot of unwanted ads and texts to your phone.
Posted 12 June 2006 - 08:33 PM
I'm thinking the coil has had it.
dev
Posted 12 June 2006 - 09:12 PM
Have you changed the clutch while it was out?
Plug leads on the coil in the right order??
Posted 12 June 2006 - 09:53 PM
Leads in right order. bottom left is one and clock wise round??
yes clutch was changed and everything adjusted properly
dev
Posted 12 June 2006 - 10:03 PM
Sprocket will be able to tell you how they go.
Posted 12 June 2006 - 10:06 PM
And the coil is, 1,2,3,4 anticlockwise when looking at the coil with the LT connector plug at the bottom, No1 is the bottom left
Posted 12 June 2006 - 10:27 PM
poo wrong way round thatys because i was tired that. i'll check in morning.
