Posted 15 April 2014 - 01:27 PM
I currently own a 1992 998cc mini, I'm currently doing a little project at the moment and would like to know what the next best thing performance wise is do on the mini, currently the mini has a stage 1 kit.
I have just overhauled the suspension, brakes dampers ect, these have been up graded to hi lo's, moulton rubbers, gaz lowered dampers, 4 pot alloys calipers, adjustable tie bars, 7.5 disc conversion, poly bushes all round.
I'm not looking for an amazing amount of power but a little kick budgeting £500-700, any information or pointers, difficulty ,costs ect....or what have you done to your mini, power increase costs ect.
Thank you
by the way beautiful weather :)
Posted 15 April 2014 - 01:34 PM
Posted 15 April 2014 - 02:10 PM
Worked head
MG Metro/Kent 266/276 cam
What carb have you got on it at the moment?
Posted 15 April 2014 - 03:08 PM
Regarding carb good question I believe it is a standard HS4 1 1/2 believe needle is aaa, just going from previous owners paper work.
Posted 15 April 2014 - 03:13 PM
Posted 15 April 2014 - 03:24 PM
Yep, single HS4 would be good, or single HIF38 if you wanted something a bit more modern.
Alternatively, you could get a set of twin HS2s, they will give you a bit more torque and better throttle response. If you 'vizardise' them, they will be as efficient as a pair of HS4s as well. Twin HS2s aren't too expensive either. I picked up a set the other day for £50 delivered.
Posted 15 April 2014 - 03:30 PM
Probably a silly question how can I tell difference from the carbs, the reason why I am saying this is I run a property clearance company and the other day we came across about 15 boxes full of mk1-mk4 engine parts , electrical ect and from my memory there were about 3 dozen carbs, so I could check there first, but knowing which is which is my problem ( sorry if a silly question , knowing my luck it's printed on carb :))
Posted 15 April 2014 - 03:35 PM
Nice head, MG Metro cam.
Posted 15 April 2014 - 03:41 PM
Posted 15 April 2014 - 03:44 PM
Posted 15 April 2014 - 05:20 PM
Do like me :)
12G940 head (18cc chambers)
Kent MD276 cam (270/280)
MegaJolt
2 x HS2
Freeflow manifold + RC40 exhaust
Should give me close to 60bhp I hope.
Posted 15 April 2014 - 05:29 PM
Posted 15 April 2014 - 06:01 PM
55-65 bhp would be a nice achievement currently 45bhp
Posted 15 April 2014 - 07:09 PM
£free carb flowing
£10 inlet manifold
£acquired 295 head
£50 lcb
£15 exhaust (homemade from pieces from a scrap yard)
£70 electronic dizzy conversion
^ = 56 BHP
now has a Piper 255 cam and I reckon it's now at about 65 although haven't had it rolling roaded
Posted 15 April 2014 - 07:43 PM
i got 65 bhp from mine but cost more than £700 :L
if your gonna go to the length or changing things you may as well over haul the engine because it has to come out to change the cam anyway
Mini Technical Sections →
Problems, Questions and Technical →
‘93 Spi Downpipe ReplacementStarted by ShabbyMini , 03 Apr 2025 ![]() |
93 Italian Job Wont StartStarted by Mattnumber2 , 28 Mar 2025 ![]() |
NewbieStarted by adenton , 23 Mar 2025 ![]() |
Tips On Buy An Used Su Hs4 CarbStarted by hfolguera , 17 Mar 2025 ![]() |
Engine Has Been Sat 10 YearsStarted by JHN_mini , 15 Mar 2025 ![]() |
