Front To Rear Ride Height Difference
6 replies to this topic
#1 bikewiz
bikewiz
  • 320 posts
  • Local Club: NEMO
Posted 15 April 2014 - 02:04 AM
So I searched "ride height" and got over 1000 topics, so after the 400th or so post I read I gave up looking. I'd like to know the height difference between the front and the rear on a mini with standard trumpets so I can adjust my HiLo's accordingly. Every stock mini I've looked at in pictures appears to sit higher in the back but by how much?
#2 russo
russo
  • 191 posts
  • Local Club: Minis In Nelson Inc.
Posted 15 April 2014 - 02:59 AM
I have HiLo's fitted to my Mini on 13 inch wheels and have front and rear set the same. Is this incorrect?
#3 A-Cell
A-Cell
  • 1,610 posts
Posted 15 April 2014 - 06:34 AM
Standard alloy trumpet lengths
front trumpet height as standard is 3.750" and the rear is 12.375" on the latest post 1979. The earlier ones were around 12.125". Dimensions from the knuckle end to the rubber cone seating face.
And yes standard the rear ride height is higher than front.
#4 maccers
maccers
  • 1,867 posts
  • Local Club: LSMOC
Posted 15 April 2014 - 07:30 AM
Mine are set to:  (in mm measured from the sill trim to the floor)
Front Height 220ns 220os
Rear Height 240ns 240os
I'm using standard cones and Hi-Lo's all round.
#5 bikewiz
bikewiz
  • 320 posts
  • Local Club: NEMO
Posted 15 April 2014 - 11:28 AM
I actually measured the original trumpets and set my Hi-Lo's accordingly but the cones settled a little different on each corner. So I wanted to get an idea of the measured height difference, from what maccers states it looks to be around 1" higher in the back.
#6 firstforward
firstforward
  • 824 posts
Posted 07 June 2014 - 06:11 AM
Does this help you
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 07 June 2014 - 09:26 AM
None of those dimensions relate to the ride height, they are body dimensions for checking for accident damage at a BMC workshop. The heights relate to a fixed datum point rather than the road, which is used specifically to eliminate ride height from the measurements to make it more accurate.
