Hi
So Im building a mini7 engine for my race car, and it has to run a single choke carb, so a single choke of a weber45 is the one to use!
How on earth do I do it though? I've got a normal 45 I can modify, do I just take the jets out and solder the ends up? That should work?
Someone must be doing it there is a full grid of minis with these carbs!
Mini7 Engine - Split Weber 45 - De-Activating One Choke
Artful Dodger
, Apr 14 2014 06:09 PM
engine
No replies to this topic
Mini Technical Sections →
Problems, Questions and Technical →
Which Ignition Coil?Started by daddums , 27 Jan 2025 engine, electrical |
Air Conditioning For 1960 Mk 1Started by Oldkartracer , 17 Jan 2025 engine, electrical |
Can You Help Me Guys With My Hs4Started by Notwabel , 26 Dec 2024 engine |
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 engine |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 engine |
