Cool, think I need to buy myself some axle stands and a bottle jack then
Quick Guide To Adjusting Front And Rear Hilo Suspension?
#16
Posted 14 April 2014 - 11:11 AM
#17
Posted 14 April 2014 - 11:24 AM
I never use axle stands as i can never get them under but i dont recommend this!Cool, think I need to buy myself some axle stands and a bottle jack then
#18
Posted 14 April 2014 - 12:03 PM
I don't recommend this either! If you never use axle stands we might as well say goodbye to you now!
Just in case, you know!
#19
Posted 14 April 2014 - 12:05 PM
Okay, just bottle jack it is then
#20
Posted 14 April 2014 - 12:06 PM
Wouldnt it be 30cm?
2,3m spanners!You need 2 300mm adjustable spanners or similar.
I read 2300mm My brain stopped for a moment when I read that, one of those "huh" moments
#21
Posted 14 April 2014 - 02:41 PM
I wouldn't, you end up quite a way under the car. If the jack slipped it would be very bad indeed. Get a decent trolley jack and axle stands. They will happily go under the front subframe. NEVER work under a car solely supported by a jack, it's the last thing many mechanics have done.Okay, just bottle jack it is then
#22
Posted 14 April 2014 - 03:33 PM
Like Tamworthbay said, get yourself a trolley jack and axle stands
http://www.screwfix....CFUoOwwod76kAxg
Iain
#23
Posted 14 April 2014 - 03:39 PM
I have actually been under a car when the jack has failed. Luckily it was a Landrover so the ground clearance was high anyway, I also only had it jacked up a bit, so the wheels were about an inch off the ground. The jack slipped and it fell over.
This was with the factory bottle jack on gravel, a recipe for disaster.
#24
Posted 14 April 2014 - 04:01 PM
Edited by Moggyton, 14 April 2014 - 04:02 PM.
#25
Posted 15 April 2014 - 09:29 AM
Okay, thanks guys.
