z-cars gsxr1000 minus
215 replies to this topic
#106 Andy gsxr minus
Andy gsxr minus
  • 52 posts
Posted 31 January 2008 - 04:20 PM
These have been bonded on with Petes windscreen glue to small L shaped brackets 7 inches apart so i have the option of screwing some studs in
later on should i prefer the look, but looking at it now i think i like them flush. very fussy bar steward me! just ask Pete :)
Took hours to get one to fit perfect but very pleased with the finished look!
#107 philly c
philly c
  • 316 posts
Posted 31 January 2008 - 05:38 PM
very impressed with the look they are lush!keep it up!
Phil
#108 pete
pete
  • 680 posts
Posted 17 February 2008 - 05:48 PM
Bit more progress today. Andy got the boot and bonnet painted.
Everything under the bonnet finally fitted (just needs a bit more wiring finishing)
And a couple more wheel arches fitted (just 1 left)
Don't think it'll be ready for cadwell though :P .
Pete
#109 Andy gsxr minus
Andy gsxr minus
  • 52 posts
Posted 17 February 2008 - 07:11 PM
The bonnet and boot weren't painted outside just in case anyone thought so... :P
Just final drying.
#110 pete
pete
  • 680 posts
Posted 16 March 2008 - 08:47 PM
Bonnet stripes added. Just needs laquering so it can be polished to match the rest.
The hole in the bonnet is for the fuel cap.
And started fitting gauges in the dash. Square hole is for the gear indicator.
#111 markrally
markrally
    Z Cars
  • 1,378 posts
  • Local Club: Miniaddicts.co.uk
Posted 16 March 2008 - 09:05 PM
Looks great but when are we going to see the finished article???
#112 pete
pete
  • 680 posts
Posted 16 March 2008 - 09:22 PM
Originaly it was due to be registered on a '56' plate but then we put it back to an '07' plate. Will definately be registered on an '08' plate so will be out and about this summer.
Maybe :)
#113 Ade
Ade
    the bogie man
  • 2,357 posts
Posted 17 March 2008 - 09:21 AM
Finally recovered enough to work on it after vegas then? ;D :D
#114 Dolts
Dolts
  • 555 posts
  • Local Club: Tyred and Exhausted
Posted 22 March 2008 - 10:53 AM
Looking great! you will have to make sur you bring it for a buzz or two through cranfield!:D
#115 pete
pete
  • 680 posts
Posted 05 April 2008 - 08:17 PM
Few steps backwards last week. When Andy went to lacquer the bonnet he decided that he wasn't happy with the stripes. They had some marks in them where they had been rolled up by the shop. Peeling one of them off took some of the paint off as well so it was back to stage one. Bonnet was striped back and re-primed. He then painted the stripes on white before some delicate masking and painting the bonnet red again.
Carefully cleaning up the edges by hand to get a clean line.
Finished result looks a lot better than the stickers ever would.
#116 brandon7
brandon7
  • 274 posts
Posted 06 April 2008 - 12:16 PM
Is this just a piece of aluminium pipe welded to the fuel tank in the front and bending to you filler cap there
? Are there any safety implications in this stuff? Especially in competitive sport? One way valves etc? Or just a metal pipe? Curious
#117 pete
pete
  • 680 posts
Posted 06 April 2008 - 08:31 PM
Will be just a bit of ally tube joined with a couple of bits of flexi hose. Can't see any problems with it this way as a lot of production cars were built like this(just the tanks in the back). The filler cap will be fixed in place permanently and the bonnet will just open around it. Didn't want the hassle of opening the bonnet every time you need to fill up. Car will never be used as a race car whilst Andy owns it so doesn't matter about any competition regulations.
#118 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 16 April 2008 - 04:15 PM
Will be fine for most track days but for racing or sprints, most tracks won't allow a car with an external filler that is solidly mounted to a tank, in case of impact snapping it off or puncturing the tank.
#119 pete
pete
  • 680 posts
Posted 20 April 2008 - 08:24 PM
Not much done this weekend as we went to Rockingham to watch the raceing but Andy did manage to finish polishing the bonnet yesterday
And a hedgehog's eye view.
Andy's now decided he doesn't like the 2 holes for the subframe mounts so these will now be fibreglassed over and painted. Will still be able to access the bolts from behind the front panel(will just be a bit fiddly).
Doors will be here soon so can get them fitted ready for painting and due to some changes at work I can start to get on with it again now so should start to see some real progress.
Edited by pete, 20 April 2008 - 08:26 PM.
#120 paulrockliffe
paulrockliffe
  • 1,763 posts
Posted 24 April 2008 - 12:07 PM
My Minus has never had those holes, the only way to undo the tie-rods is to drop the subframe out of the car, more than a little bit fiddly!
