z-cars gsxr1000 minus
215 replies to this topic
#136 THE STIG
THE STIG
    Da stig says, GO GO GO
  • 2,506 posts
Posted 22 February 2009 - 06:15 PM
looking and sounding good pete
about time only sold him the shell 3 years ago lol
hope to be seeing it out and about at shows this year andy
#137 Andy gsxr minus
Andy gsxr minus
  • 52 posts
Posted 22 February 2009 - 06:23 PM
Can you believe that was 3 years ago!!!
Just got my ticket through the post for the London to Brighton run, so that will be the first one we will be at.... :lol:
Not been able to give them a reg number yet as it hasn't got one.... just put 09 on the application form :dontgetit:
#138 THE STIG
THE STIG
  • 2,506 posts
Posted 22 February 2009 - 06:45 PM
Just got my ticket through the post for the London to Brighton run, so that will be the first one we will be at.... :D
Not been able to give them a reg number yet as it hasn't got one.... just put 09 on the application form :D
i know still have the pics from when i had it
not sure if will be at london to brighton
but deff want to see it at some point
got to be the best looking minus about + zcar as well
09 plate nice
#139 Ade
Ade
    the bogie man
  • 2,357 posts
Posted 24 February 2009 - 10:36 AM
Nice to see Pete's standard "gentle" run in period is still the same :P :thumbsup:
#140 pete
pete
  • 680 posts
Posted 23 March 2009 - 07:14 PM
Finally finished and all ready for it's sva tomorrow.
Think I should have got a bigger trailer. It's a bit of a squeeze :wub: :wub: :wub:
#141 stooart
stooart
  • 168 posts
Posted 24 March 2009 - 03:58 PM
just read through this! and wow is all you can say! car looks sweeet! i really like the look of that back end.
have fun with it!
stu
#142 pete
pete
  • 680 posts
Posted 24 March 2009 - 04:02 PM
Arrived at sva centre 8am and had all the whole test centre to ourselves.
Good news is that it only failed on a few little things mostly relating to radiused edges. Front and rear lights too low and emissions way too high. About a days work and a trip to the local mot centre to adjust the emissions. Aiming for retest within 2 weeks.
Noise limit passed by 1 decibel using 2 exhaust cans and a cat.
#143 edsmini
edsmini
  • 357 posts
Posted 24 March 2009 - 04:06 PM
car looks great pete, red minis look great. maybe because mine is red too !!!
screw the shocks right up to get the lights at the correct height?
Eddie
Edited by edsmini, 24 March 2009 - 04:09 PM.
#144 pete
pete
  • 680 posts
Posted 24 March 2009 - 04:24 PM
Tried that when we got home but the rears need to go up by about 6cm so would look a bit silly. Decided to cut the holes higher and then fibreglass up the holes left under the lights. Just means Andy will have to repaint the back end again.
Adjusted the front shocks to raise the front indicators as they only needed to be slightly higher.
#145 edsmini
edsmini
  • 357 posts
Posted 24 March 2009 - 08:49 PM
there is nothing straight forward with these sva tests grrr. i built a dax rush a while back and i was at the bishopbriggs sva test centre in glasgow for 7 hours. and the only thing he could find wrong was the speedo was 5mph out but that is all water under the bridge
eddie
#146 koss
koss
  • 1,399 posts
  • Local Club: The Greenbank working mens social club
Posted 25 March 2009 - 09:01 AM
well done pete. Are your lights lower than 250 mm ? cant tell off looking at the pictures. just mesured the monte ones at 350mm at the lowest point and i thought the monte sat low.
#147 pete
pete
  • 680 posts
Posted 25 March 2009 - 04:30 PM
Looking at the picture's they don't look that low but were measured at about 290mm and need to be 350mm. Only the fog light is 250mm minimum. I think the problem is because when the holes for the lights were cut they were lined up with the bottom edge of the boot opening. Spent age's deciding where to fit the fog light to get it high enough without ruining the smooth look that I didn't even bother checking the height of the other light's.
I think we were lucky with the speedo reading because we have fitted the sensor to the front wheel. He wasn't able to test it in the rollers because it requires the engine to drive the wheels. He drove it around the building and said that works ok but I would recommend checking it with a sat nav when you get it on the road just to make sure.
We were very happy to come away with such a small and simple list of fail points. Could have been a lot worse.
#148 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 26 March 2009 - 02:13 AM
That lights issue is a bit of a bummer, but at least the end is in sight!
#149 koss
koss
  • 1,399 posts
Posted 26 March 2009 - 09:16 AM
Ooops yes its 250mm for fog lights and front indicators I believe, could be wrong. Speedo I usually set to read fast 8mph than the actual speed. Newcastle sva has driven rollers so they can check either setup. At least you made the sva deadline. The new IVA it going to be interesting :D
#150 benmini
benmini
  • 167 posts
Posted 30 April 2009 - 06:17 PM
Just read the whole thread! beautiful and awesome car!! any updates - did it pass the SVA? I'll try and find you at shows this year. lol
I'm planning on building a minus soon-ish!
