Windscreen Washer Is Just Awful
22 replies to this topic
#16 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 13 April 2014 - 01:32 PM
93, washer bottle in the boot
Ok,
What you need to do is Remove the washer bottle by lifting it vertically from the clamp,
Then remove the hose from the round inline filter
Then ask someone to operate the pump, it should flow steadily
Get an airline and blow the pump through the shotr piece of hose, then re-test the pump... Has it improved?
To change the hose in the pillar, you can tape the new hose to the old one and gently pull it through
Pump is fine, filled up a mug in about 3 seconds, the problem seems to the the roof lining pipe :(
Does that mean the roof lining has to come out?
Ok,
Or just read your tape idea haha!
The tape idea will work as there is no wiring to be interfered with :)
#17 willava182
willava182
  • 704 posts
Posted 13 April 2014 - 02:39 PM
Best I had was a bike pump, seeing as the pipe is black not clear as it is meant to be... I'll just get a new pipe all round
#18 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 13 April 2014 - 02:41 PM
The black stuff is smaller bore
#19 willava182
willava182
  • 704 posts
Posted 13 April 2014 - 02:44 PM
As in black with gunk!
#20 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 13 April 2014 - 02:58 PM
Aww haha
#21 willava182
willava182
  • 704 posts
Posted 13 April 2014 - 03:00 PM
Aww haha
To minispares it is!
#22 willava182
willava182
  • 704 posts
Posted 13 April 2014 - 03:01 PM
Do you know what size pipe I need for the d shaped jets?
Is it 5mm?
#23 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 13 April 2014 - 03:03 PM
Erm 7 mm i think
