Mig Welder
21 replies to this topic
#1 pierres
pierres
  • 586 posts
  • Local Club: No
Posted 12 April 2014 - 08:15 AM
Looking to get a good second hand mig welder what is a good make and would it be best to go the gasless route or with gas
#2 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 12 April 2014 - 08:19 AM
Definitely use gas.
As for make, a fair few of us on here will recommend the Clarke 135TE. As well as a 135 I also have a fairly old Sip migmate and it is just as good and could probably be picked up for half the price of the 135 second hand
Edited by megamini_jb, 12 April 2014 - 08:20 AM.
#3 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 12 April 2014 - 08:30 AM
135te turbo is a fantastic welder. I had a sip once and was really poor. But i may have had a bad one not sure, i will never own another though. Also deffinatly use gas!
#4 Covert
Covert
  • 526 posts
Posted 12 April 2014 - 08:41 AM
Gas ! Its worth the extra money, plus if you haven't welded before it will make it much easier to learn plus cleanup is quicker
#5 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
I have a sealey supermig 185, its epic
#6 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,025 posts
Posted 12 April 2014 - 08:47 AM
clarke 135te for me too, and definitely use gas.
#7 yamkid360
yamkid360
    Just On Tickover
  • 5 posts
Posted 12 April 2014 - 09:41 AM
I would definately recomend using a separate gas bottle setup (Argashield 5 or Migweld Universal) .I use a Clarke 160T for heavy work , but find the Clarke 120E mk2 brilliant for lighter guage steel on body work. The fluxed wire system is very limited and will yield poor results in inexperienced hands. After working with your welder always take your mig wire reel into the house ( I know its a pain spooling up every time you want to use it ) to keep it dry as wire tends to rust quickly these days , rusty or damp wire will also result in poor welding.
#8 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 12 April 2014 - 10:20 AM
Another vote for the 135TE. It will do everything you need on a mini with ease. Do not go gasless, unless you are skilled at using it, there are quite a few places you can get Argoshield light from. Adams Gas, BOC for example. They vary in price so get what is suitable for your pocket.
As for removing your spool of wire, if it's a long period yes do so but otherwise Silca Gel bags / desiccant crystals will keep moisture at bay in the short term. These can be bought off EBay.
#9 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 12 April 2014 - 10:48 AM
I bought a second hand Clarke 160EN Gas / Gassless and use a 9 Ltr Argon CO2 Mix, they are really good Mig Welders, the 160 is an older model and everyine here seems to be recommending the 135TE.
Here's a link to the 135TE Turbo on Machine Mart, its just under £290 but i'm sure you can get it cheaper.
I use Adams Gas 9Ltr its about £50 deposit and £37 for the gas, there are better deals but it was the only one local. I have just had a refil, handed in a gleamingly clean new bottle and got handed a minging bottle with corrosion around the base of the main valve (my wife collected while I was away) grrrrrrr
The only problem with Adams and another company around here is that the only fill the 9Ltr bottle to 137 Bar so you don't get as much gas.
You'll also need an Argon Regulator / Flow Meter.
You may also want to change the standard Earth Clamp, not sure what the one on the 135TE is like but mine was not brill, so I changed it for a better one (e.g. 200Amp), something like this  I got mine from Wellington Welding (even cheaper).
Edited by JonnyAlpha, 12 April 2014 - 10:55 AM.
#10 Sean C
Sean C
  • 196 posts
  • Local Club: ESMOC
Posted 12 April 2014 - 11:19 AM
Clarke 135te is a fantastic bit of kit. I've had mine for a few years now and cant fault it
#11 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 12 April 2014 - 11:41 AM
Heres my 135te i use a large bottle so to the trolley comes in very handy!
#12 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 12 April 2014 - 11:47 AM
Yeah defo get a trolley too.
#13 Twincam
Twincam
  • 1,742 posts
  • Local Club: SMAG
Posted 12 April 2014 - 12:01 PM
I've got a Sealey 230TE Turbo - bought from machine mart when they had a 10% off day iirc.
Deffo go for gas, buy once, buy proper...
#14 newenglandmini
newenglandmini
  • 646 posts
Posted 12 April 2014 - 12:24 PM
I recommend a gasless flux wire welder.  I use this one, which costs less than 65 GPB.
http://www.harborfre...68887-8494.html
Gas is expensive and cumbersome.  Flux wire is quicker and easier to use and can provide good quality welds when used properly.  I have welded sheet metal and stock up to 0.25" thick.
The key to getting good welds is to prepare the metal carefully to ensure cleanliness and lot's of practice on scrap bits.  Procuring a variety of sheet metal clamps is also essential.  I spent hours viewing instructional clips on Youtube and making practice welds.  With careful cleaning of the metal surfaces and practice, use of a inexpensive flux wire MIG welder will provide welds every bit as good as to be had from more expensive systems.
In outdoor settings, the flux wire welder is actually superior, because the presence of wind will reduce the effectiveness of a gas-shielded welder.
#15 pierres
pierres
  • 586 posts
  • Local Club: No
Posted 12 April 2014 - 06:06 PM
Hi guys
Thanks for all the advice looks very useful will start looking for a welder now and when I get one will start welding and will post pics for you to tell me if everything is ok or not
Thanks agian
