Posted 04 April 2014 - 09:31 PM
Posted 04 April 2014 - 09:34 PM
Are you looking to rebore to produce more power?
The big limiting factor with an A series engine is the head, and bigger valves, correct compression ratio and porting and polishing will give you more of a gain than just reboring.
What do you plan to use the car for? Once you've answered this people will advise on cam choice etc
Posted 04 April 2014 - 09:35 PM
I would go to 1293, theres no point boring it straight out to 1380 as the blocks scap after that.
Posted 04 April 2014 - 09:46 PM
There are standard sizes you can rebore to, 1293cc, 1330cc, and 1380cc are the most common, the largest 1380 requires the cylinder bores to be 'offset bored' which means two cyl's need to be offset slightly, this is to improve the longevity of the head gasket, this does however mean if the block needs to be bored out further due to wear it will require relining (a sleeve put into the bores) and then removing the offset can be tricky - hence usually not financially viable and a block scrapped.
The gain over 1330cc isnt much so going the full 1380 is generally regarded as pointless for a road car, and personally I would go for 1293cc, thats what historic racing minis run (due to regulations) and they go well enough ;)
Posted 04 April 2014 - 09:51 PM
Posted 04 April 2014 - 09:53 PM
Thanks for the quick replies. If I bored it out to 1293 would I require different pistons or would standard ones be Ok? And the same for 1330?
re-bore would require different pistons
Posted 04 April 2014 - 09:56 PM
Posted 04 April 2014 - 09:58 PM
Cheers for that Carlos. If I bored it 1293 what pistons would I require? And is there anything else engine wise I would require?
Posted 04 April 2014 - 10:04 PM
+0.020
Minispares would be a good place to start, but as above, what are you hoping to achieve??
Posted 04 April 2014 - 10:05 PM
+0.020
Cheers I'm looking for an all round bit of gain on performance really the car is going to be a show car really but would like it to have a bit more power as it stands really, looking for better acceleration, top speed and torque general.
Posted 04 April 2014 - 10:06 PM
+0.020
You're going to need some head work done, correct compression ratio and a decent fast road cam.
What's your budget?
Posted 04 April 2014 - 10:11 PM
Not really had a look at budget yet just want to get basic idea of what I need to get first.
Cheers I'm looking for an all round bit of gain on performance really the car is going to be a show car really but would like it to have a bit more power as it stands really, looking for better acceleration, top speed and torque general.+0.020
What's your budget?
Quick question just had a look on Minispares at there pistons, and they have a selection going from +60 to +20 I'm guessing that the +20 is for 1293 +40 1330 and +60 for 1380. Please correct me If I'm wrong.
And what head work would be needed?
And what cam would you recommend?
Posted 04 April 2014 - 10:12 PM
First the bores need to be measured to see what the size in now, and that will determin what the next size of rebore will be and go from there.
Posted 04 April 2014 - 10:13 PM
What's your budget?
Also what's the difference in between dished and flat top mega pistons?
Posted 04 April 2014 - 10:19 PM
Slightly larger bore alone will do little to help. As others have said getting the engine to breathe better and throw more fuel in will help much more. This means inlet, exhaust, head, valves, cam, even a lightened and balanced bottom end to help the engine rotate and rev will make a nice difference.
Have you got the 1275? Are the bores scored and does it need a rebore? If not - why bother?
If the car is only a toy/show car, consider changing the final drive and playing with the gearbox to get better acceleration.
Without meaning any offence, and it's good that you've come here to ask the questions, you need to read or find videos and websites that teach you how an engine works in basic terms and how changing this or the other will improve things. That's not meant as a dig and I'm sure no one here has a problem helping, but if you understood you'd be able to work out what step to go to next and what will make the biggest difference to your current set up.
Mini Technical Sections →
Problems, Questions and Technical →
‘93 Spi Downpipe ReplacementStarted by ShabbyMini , 03 Apr 2025 ![]() |
93 Italian Job Wont StartStarted by Mattnumber2 , 28 Mar 2025 ![]() |
NewbieStarted by adenton , 23 Mar 2025 ![]() |
Tips On Buy An Used Su Hs4 CarbStarted by hfolguera , 17 Mar 2025 ![]() |
Engine Has Been Sat 10 YearsStarted by JHN_mini , 15 Mar 2025 ![]() |
