Mini Just Wont Rev Up
19 replies to this topic
#16 mintyminis
mintyminis
  • 79 posts
Posted 09 April 2014 - 07:50 PM
hello all
I have taken the carb off today and started having a look inside the float chamber..i have taken a picture of the jet assembly and
it doesn't look right. .  there is a metal ring around the plastic bit at the bottom, does anyone know if it should be that far down?
10153153_10152151061323768_7811957506850
#17 mintyminis
mintyminis
  • 79 posts
Posted 11 April 2014 - 07:16 PM
anyone have any ideas if this ring meant to be that far down?
thanks
#18 sledgehammer
sledgehammer
  • 3,098 posts
Posted 11 April 2014 - 07:30 PM
https://minispares.c...4.aspx?2~18~172
not clear
http://www.ebay.co.u...=item417f451efe
bit clearer
for the metro 1300
http://sucarb.co.uk/...plications.html
have a good look around the SU site for info
Edited by sledgehammer, 11 April 2014 - 07:52 PM.
#19 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 11 April 2014 - 08:20 PM
I don't think anybody has said this yet. Seeing as you temporarily fixed the problem by cleaning the carb, do you have a filter fitted and are you running low on fuel in the tank (supposedly where all the sediment is)
Edited by Stiggytoo, 11 April 2014 - 08:21 PM.
#20 mintyminis
mintyminis
  • 79 posts
Posted 28 April 2014 - 06:01 PM
hi all
manage to get the car running again over the weekend after giving the carb a good clean..there was a quite bit of dirt in the fuel feed pipe on side of carb.
fitted a new service kit and put everything back together..and now the car running sweet! i can only think it was the dirt in the fuel pipe could had been the problem so im going to fit a inline fuel filter,, many thanks for the replies as they have been
helpful,,
