Air Compressor Advice And Reviews?
Posted 25 March 2014 - 08:08 PM
Thank you for the help in advance!
Posted 25 March 2014 - 08:15 PM
Bigger is better here. At a minimum 100 ltr and 3 hp. This will be enough to run most air tools. However when it comes to spraying you won't be able to use this for spraying and providing breathing air.
You may also find you will have to upgrade your electrics to run the compressor especially for initial start. I have mine on a separate circuit with a 20 amp Mcb breaker.
Posted 25 March 2014 - 08:54 PM
Don't scrimp on this. Good advise from sonikk4. You don't want to pull the trigger on the spay gun & all the airs gone. Get a decent capacity & supply.
Posted 25 March 2014 - 09:25 PM
Sealey do a good range of compressors
Posted 25 March 2014 - 09:45 PM
Posted 25 March 2014 - 09:48 PM
I have a Clarke
http://www.machinema...tre-air-compres
it noisy as well but does everything i want from it. I will use it for spraying but i have another compressor than can be used for breathing air.
Posted 25 March 2014 - 10:39 PM
Posted 25 March 2014 - 10:44 PM
Ahh yehh I see.. That's exactly what I need like something portable. So what's this with the breather? I havnt sprayed before was going to look into it closer to the time but now it's here could you explain please?
Do you mean the breaker?? on start up it draws a lot of current and will trip a standard 13 amp socket / fuse / circuit breaker. I installed a separate circuit with a stand alone 20 amp Mcb. This takes the start up draw without tripping. I also have this circuit installed for my spot welder as well.
Posted 26 March 2014 - 06:47 AM
Posted 26 March 2014 - 06:50 PM
http://www.machinema...ressor-se16c100
I have used this with a da sander and although it works hard it doesn't drop pressure, also used for spraying and with an airfed mask.
When using airfed though I have a devilbiss mask with correct filtration and only use a devilbiss sri pro spraygun as it's air consumption is low, I also lowered cut out pressure on compressor to 8 bar under recommendation of a compressor specialist to help reduce heat build up and although it runs approx 50% of the time in this application I have had no issues and never had the whistle on the mask go off. If I needed to use a full sized gti pro spraygun I would need to run two of these compressors but I have easily painted a full mini with my gun as it has a very good fan pattern and you can get larger cups for them.
Edited by Daz1968, 26 March 2014 - 06:52 PM.
Posted 26 March 2014 - 08:16 PM
I bought one of these last year as a general air tool compressor and I've been really impressed. Especially at the price...
http://www.kendaltoo...=showprod_06245
Also it's very manoeuvrable and because it's vertical does not take up a lot of space.
Posted 26 March 2014 - 10:04 PM
I do like the sounds of it.. Sounds just perfect for the job but yeh thank you for that sounds perfect thanks for the detail as well..I have a clarke se16c100 its a 3hp with 100 litre receiver and cast iron cylinders as the linkhttp://www.machinema...ressor-se16c100
Posted 26 March 2014 - 10:07 PM
this sound good as well and yeh I do like the price on that one hahaha,, have you ever sprayed with this compressor? This is the main reason I'm buying one.. Along with the tools hahaI bought one of these last year as a general air tool compressor and I've been really impressed. Especially at the price...
And thank you for all of the help from everyone as well is helping a lot!
Posted 27 March 2014 - 08:14 AM
I use it for spraying blocks and heads with a small HVLP no issue, and it's bigger in tank and CFM to the one I sprayed my mini with many years ago.
I also use it for air drills and high speed die grinders and copes well with them and tey are very air hungry. Don't think it would cope well with blasting tho'
Posted 27 March 2014 - 09:33 PM
