Best Wheel Size For Fast Rroad Use
Posted 24 March 2014 - 10:52 PM
I originally want some 13"x 7" deep dish but it seem that there is issues with them fitted. At the moment the ride is quite harsh and bumpy. Will 12" or 10" rim would make the ride better without compromising the grip and cornering?
Posted 24 March 2014 - 11:11 PM
Posted 24 March 2014 - 11:28 PM
The design of the Mini, which was done in 1958, required the tyres to do some of the work of the suspension, which is why a 10" wheel with a deeper wall height works so well compared to the 175/50 x 13" tyres. Also the wide 13" wheels spoil the scrub angle of the steering geometry.
One of the nicest handling Minis I've driven in a long time was a 1997 Cooper MPI on 12" wheels with 145/70 x 12 tyres. Not the ultimate road holding, but adequate, and fabulous handling.
IMHO the 13" wheels are one of the silliest things ever done by Rover to the Mini design in terms of ride, wet road-holding, wet skid resistance, handling and appearance.
Posted 25 March 2014 - 12:48 AM
I have a set of 5x12 ultralites and I think they are probably the best compromise between grip/handling you will find, as well as allowing you to to fit 8.4 discs which have a slight advantage in terms of stopping power, as well as giving you the option of vented metro turbo 4 pots should you want them.
Posted 26 March 2014 - 11:06 AM
Ash.
Posted 26 March 2014 - 11:20 AM
Fast road means you need decent handling and road holding, so wheel width must be 4.5 or max 5", either 10" and 12" wheels are proven to be good, probably a 12" will give a slightly better road holding.
Posted 26 March 2014 - 07:53 PM
Very nice car. Those wheel sfill nicely the arch wheels. What size tyres have you got?I have 6x12 JBW Mambas, they handle far better than with my previous 13s because of the bigger sidewalls. Just wish I could fit 10s over my Metro four pots!!.
Ash.
Posted 26 March 2014 - 08:57 PM
Ash.
