What Grit Grade?
Posted 21 March 2014 - 10:42 PM
Also best place to buy.
Posted 21 March 2014 - 11:10 PM
Posted 21 March 2014 - 11:13 PM
80 grit - primary rubbing down stage / cutting filler into shape
120 grit - reducing sharpness of the cut of 80 grit.
240 grit - same again, finer grade, making it smoother for paint
380 grit - a finishing grade, good enough for high build primer to be applied over.
500 - course wet and dry for cutting back undercoat
800 - fine wet and dry for finishing touches of undercoat ready for top coat
this is all with use of a block for 80 grit and shaping the bodywork, and then a DA sander for the rest. if you do it by hand, the finish is less polished and id say go to 1200 grit for the final stage
to do a good job on the exterior you need it all. i get all my paint supplies from BEEBEE paint suppliers as they deliver to me and are fairly local:)
Posted 22 March 2014 - 06:53 PM
Posted 30 April 2014 - 08:40 PM
What DA would you use?
I borrowed one years ago when spraying a shell but need to sort my own this time. The one I used was rectangular that you could clip cut W+D sheets to. This seemed more economical than a round one requiring discs. I have a polisher so don't need it to double up.
