Best Ever A-Series Power On Twin Hs2 Su's?
17 replies to this topic
#1 carbon
carbon
  • 2,590 posts
Posted 21 March 2014 - 05:33 PM
Just been flicking through the April issue of Mini Magazine, the article on Jonathan Lewis's 1275GT grabbed my attention. He's using a Paul Inch built 1293, and getting 112bhp at the wheels with a 649 cam and 1.5 rockers - so there should be a lot more than this at the flywheel.
The really interesting bit is that his car is running with twin 1.25 inch HS2 SU carbs, which are considered by many to be on the marginal side for even mildly tuned fast road engines...
So the question is - who's the daddy with twin HS2 power output from A-Series motor?
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 21 March 2014 - 07:31 PM
112bhp at the wheels ? non turbo and SU 1 1/4s ? I know he is a respected builder but surely thats a misprint? given transmission losses then that would indicate appprox 130-135bhp at the flywheel.
Given the formula that every bhp takes 2,2cfm of air then the 1 1/4s need to flow 286-297cfm.
Edited by KernowCooper, 21 March 2014 - 07:34 PM.
#3 grumpy dad
grumpy dad
  • 305 posts
Hi
the flow rate of a pair of HS2
is the same as a single HIF44
you have a longer intake with the HIF44
so you might get a bit more torque
#4 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 21 March 2014 - 07:54 PM
Where are you getting the flow rates for a twin  1 1/4 HS2 the same as a Hif44 good, on the normal maniflod which is a log design maniflod then only one cylinder is on the intake stroke at any one time then the cfm is only what one HS2 can flow not the 2 added together due to the manifold design and siameeese inlet ports, but the true cfm will be lower for any carb once connected to  the head.
I read somewhere 85bhp at the flywheel was considdered the upper limit of standard twin HS2 setup
Edited by KernowCooper, 21 March 2014 - 07:59 PM.
#5 Cooperman
  • 23,276 posts
Posted 21 March 2014 - 07:59 PM
I think it's a misprint. Never heard of a car producing around 130 bhp at the flywheel on twin Hs2's. It's a struggle even with the 649 and twin HS4's.
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 21 March 2014 - 08:06 PM
Misprint but Paul Inchs phone will be hot no doubt :lol:
#7 grumpy dad
grumpy dad
  • 305 posts
Posted 21 March 2014 - 08:15 PM
Hi
According to David Vizard's data, the flow rates are:
1.25" H2 SU, 110 cfm.
1.50" H4 SU, 133 cfm.
1.50" HS4 SU, 142 cfm.
1.75" HS6, 210 cfm.
1.75" HIF6, 240 cfm.
#8 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 21 March 2014 - 08:22 PM
Yes agreed but on a siameese inlet no one cylinder can see more than the 110cfm of a single carb as the inlet manifold is not normally joined between inlet tracks, they are in essence two carbs on seperate inlets feeding 2 cylinders on a siameese head.
The same is true of a 40dcoe stup no 1 cylinder can see more that what ever the cfm is for a 36mm (biggest std choke for a 40dcoe)
See page 81 of Vizards Yellow Book info there on twin chokes or twin carbs and what the engine sees
Edited by KernowCooper, 21 March 2014 - 09:05 PM.
#9 Cooperman
  • 23,276 posts
Posted 21 March 2014 - 08:27 PM
Even the Swiftune FIA Historic 'S' race engines don't produce that sort of power, even for £20,000 each, with HS4's and a full race cam.
#10 Earwax
Earwax
  • 485 posts
Posted 21 March 2014 - 09:39 PM
I would think a misprint or an error repeated down the line.
On flow capacity , i am all with KernowCooper, the twins only see the stated flow rate not double as some expect, and the other factor is the flow through the carb and manifold. Whilst horsepower/bananas is a bit variable on different machines i would have thought that 112 at the flywheel was still too high for hs2s, and i have always pictured 110 flywheel approaching max for twin HS4s.  However back to the original point, it would be good to hear of results for twin hs2s
#11 mini13
mini13
  • 3,810 posts
Posted 21 March 2014 - 10:01 PM
or just another RR that over reads....
#12 ACDodd
ACDodd
  • Mini Docs
  • 2,741 posts
Posted 21 March 2014 - 10:49 PM
Standard twin hs2 and stock factory cast manifold;
100hp @ flywheel, 1330cc stock rockers, stock lift, stock 1.312" intake valve size and one very custom ACD cam.
Ac
Edited by ACDodd, 21 March 2014 - 10:57 PM.
#13 jaydee
jaydee
  • 8,565 posts
Posted 22 March 2014 - 01:35 PM
No doubt that a misprint, but i'd be curious of what inlet, ram pipes and extra work these carbs have.
Both paul inch and jonathan lewis know thir stuff.
#14 Dusky
Dusky
  • 5,322 posts
Posted 01 April 2015 - 05:29 PM
Ac
Out of intrest, how heavy were the SU's modified?
And at around what rpm did the top power come? :)
#15 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 01 April 2015 - 06:40 PM
Bit old of a thread but as Cooperman pointed out about the swiftune engine, but back to your question about 13000rpm ;D
