Can anyone advise if this can be removed from below the car.
Trying to avoid removing inlet manifold.
Also, what socket size is required?
Posted 19 March 2014 - 01:58 PM
Posted 19 March 2014 - 02:45 PM
Posted 19 March 2014 - 02:47 PM
thanks
Posted 19 March 2014 - 05:10 PM
Posted 19 March 2014 - 05:26 PM
Posted 21 March 2014 - 07:55 PM
Successfully replaced sensor.
Used a 3/4" deep socket with long extension bar, with car on a ramp.
Posted 21 March 2014 - 08:31 PM
Posted 28 March 2014 - 12:38 AM
how long roughly was the job done have the same problem
Posted 11 September 2015 - 11:49 AM
Job took about 15mins
Posted 11 September 2015 - 04:07 PM
Posted 12 September 2015 - 08:55 AM
Is there enough room for our hand to plug out the connector wire from underneath the car?
Posted 12 September 2015 - 02:58 PM
I am not a friend of doing so. I am taking off the inlet manifold for this. Advantages: check all around the manifold, cleaned it, painted it and used new seals. it is easier to check the cables and connections.
The sensor was prepared with high temperature ceramic grease so that next time it nannot corrode and works easier to get it off.
Edited by Alpenflitzer, 12 September 2015 - 02:59 PM.
