Carb
3 replies to this topic
#1 nollyd
nollyd
  • 663 posts
Posted 17 March 2014 - 05:36 PM
hi all,just a quickie.i hope.ive got an alloy inlet manifold with the four bolts to hold the carb,its 1 3/4,now i have also got an 1 1/2 hs4 su carb,will it fit,thats the question,the two hole centers i need fit great but will it work or do i need a different manifold,
also im bench testing my engine so need to know if theres a way to get the carb set somewhere near or will it be trial and error.
cheers guys
#2 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 17 March 2014 - 05:40 PM
It should fit - just remove the 2 unwanted studs and fit with the correct gaskets.
Not entirely sure, but I think you can get a baseline setup for the hs4 by winding the jet fully in, then back out 2 turns (12 flats)
#3 carbon
carbon
  • 2,590 posts
Yes it will work. Quite a few Metros from the factory used a 1.5 inch carb on the larger 1.75 inlet manifold.
#4 nollyd
nollyd
  • 663 posts
Posted 17 March 2014 - 05:42 PM
nice one guys,thanx very much for the speedy reply.
