KIFs were made for the K series, so that's the one for the Rover 100. I'm not sure it will mount to a regular flange. The Maestro and Montego had HIFs and HIF Es. The HIF E needs a few sensors, an ECU and some extra parts fitted to the carb itself to make it work. It's quite bulky. Other SU auto chokes are things like the AED and the Thermo, the latter I think was only ever used on Jaguars. But they are all bulky and expensive and you can't get much in the way of parts for them. They also only work with specific carbs that are designed for them.
It's not fair to say auto choke make the engine excessively rich. The problem is that most use a bimetallic element of some sort to sense engine temperature from the coolant, and they do nothing to sense air temperature or fuel temperature / density. Exactly where in the system they get coolant from to sense the temperature has a big impact on how they work and some are better than others. Many are OK when they are new but as they age they wear out. Bimetallic elements are supposed to be replaced every couple of years, like the air intake flap in Minis, but nobody ever does it and then they complain it doesn't work. The HIF E being electronic instead of thermally driven is probably more reliable for longer.
Edited by Dan, 17 March 2014 - 08:57 AM.
