High Build Rattle Can Primer?
8 replies to this topic
#1 bondo66
bondo66
    Starting My Mini Up
  • 1 posts
Posted 14 March 2014 - 06:38 PM
I want to use some rattle can primer to cover a few small marks on the car. I have seen some in Halfords...U-Pol £11.99 a can! Is there a cheaper alternative, or is this Halfods stuff worth the money? Any help please! Regards Bill...
#2 jb93
jb93
  • 2,439 posts
Posted 14 March 2014 - 06:41 PM
I used the Halfrauds stuff when I was patching up mine a couple of summers ago. Seemed decent stuff to be honest :thumbsup:
#3 cal844
cal844
  • 9,622 posts
  • Local Club: TFMOC
Posted 14 March 2014 - 06:44 PM
Go to a paint shop!!! Much cheapness
#4 jpw1275
jpw1275
  • 2,803 posts
Posted 14 March 2014 - 06:52 PM
U pol high build is good stuff..... But I only use it in a spray gun at work
#5 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 14 March 2014 - 07:51 PM
buy a tin of proper stuff and brush it on if u have too
#6 Daz1968
Daz1968
  • 2,058 posts
Posted 14 March 2014 - 07:55 PM
I have used upol high 5, it is ok for small jobs but must be applied very thinly else it runs or reacts with other paints. Which to me defeats the object of high build. Upol p88 in a gun is much better and 2k products better again but if you have more than minor sanding marks then use some stopper or glaze first.
Just read post above, 2k primer can be rollered in small areas and you have none of the health risks of spraying so maybe best option.
Edited by Daz1968, 14 March 2014 - 07:56 PM.
#7 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 14 March 2014 - 08:03 PM
Mipa do some good rattle can high build.
#8 cradley-heathen
cradley-heathen
    Metro-Man
  • 2,481 posts
  • Local Club: spearmint rhino
Posted 14 March 2014 - 09:37 PM
i havnt used it for a long time, but i must admit, about 10 years back i tried to use it quite a few times, and i found it reacted with almost every paint i put it near.
or, say if you were trying to do a small repair on a larger panel, i would always get a reacting directly around the outer edge where the primer faed out onto the rest of the panel.
i guess you dont have a compressor? if you do i would advise going to 2 pack primer as it doesnt seem to react with anything
#9 DangerousDave17
DangerousDave17
  • 76 posts
Posted 15 March 2014 - 08:31 AM
Halfords do they're own brand "filler primer" its yellow. It does the job after a few coats. Nothing compared to 2 pack but not bad for a small job.
