175 70 13 Tyres?
11 replies to this topic
#1 DazWood
DazWood
  • 182 posts
  • Local Club: North East Mini Club
Posted 12 March 2014 - 10:16 PM
Are these a good size to run?
They'll be going on a set on 13x7 minilites
I need a quick answer please
#2 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 12 March 2014 - 10:19 PM
I'm fairly sure that profile will to too high for a Mini.
Aren't they normally 55 profile?
#3 Kmonski
Kmonski
  • 125 posts
Posted 12 March 2014 - 10:20 PM
As said i think that is a little to high.
I run on 175/50/13 and that is perfectly fine.
#4 DazWood
DazWood
  • 182 posts
Originals are 50s. But wasnt sure if 70s would fit.
#5 Cooperman
  • 23,309 posts
Posted 12 March 2014 - 11:30 PM
They will not fit as the diameter with the 70% profile is simply too great. The only 70% tyre which will fit is a 145/70 x 12 or a 165/70 x 10. In fact both of those are better than a 13" wheel./tyre combination for a Mini.
#6 Alex_B
Alex_B
  • 4,573 posts
Posted 12 March 2014 - 11:41 PM
I believe they will hit the radius arm mount on a 13" wheel with anything larger than a 55 profile tyre
#7 Cooperman
  • 23,309 posts
Posted 12 March 2014 - 11:50 PM
On a 7" wide wheel 13" diameter, a 175 tyre is needed, thus it has to be a 175/50 x 13 in order to fit a Mini.
#8 bluedragon
bluedragon
  • 287 posts
Posted 13 March 2014 - 01:32 AM
A 175/60-13 tire will fit on a Mini - I have them and have driven on them daily for commuting as well as long tours. But it is very, very close on the rear radius arm. So it's possible some oversized 175/60-13 tires would foul.
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 13 March 2014 - 09:19 AM
When you get that close to the body the tyre make is important. It's not as easy as saying a 175/60/13 will fit. All makes have different mould shapes, some are more square at the shoulder than others of the same size. If the shoulder is very square it will hit sooner than one with a more rounded shape.
#10 jaydee
jaydee
  • 8,565 posts
Posted 13 March 2014 - 10:05 AM
Such tyres are good if you only go only on a straight line, are you a 'sleeper'?
The mini suspension is designed for 10" wheels..
#11 DazWood
DazWood
  • 182 posts
Posted 13 March 2014 - 03:58 PM
All sorted now thanks. Ordering me some 175 50 13s
#12 Midas Mk1
Midas Mk1
  • 5,781 posts
  • Local Club: S.U.N.M.C
Posted 13 March 2014 - 04:15 PM
Phh, 10's are overrated.
