Nz 1976 Austin Mini Rebuild
106 replies to this topic
#61 MasterD78
MasterD78
  • 125 posts
Posted 13 July 2017 - 05:33 PM
Fantastic build!  I love seeing when a car turns from a beat up and tired piece of metal into a fine work of art!  Great work.
#62 Chris.Williams
Chris.Williams
  • 679 posts
Posted 13 July 2017 - 06:48 PM
Have you ordered that flywheel assembly yet?
#63 NZMini1275
NZMini1275
  • 227 posts
Posted 15 July 2017 - 08:52 PM
Going to order one this week.
Been busy trying to fix a speedo problem. Got a new speedo which worked for awhile then the speedo pinion started slipping.
New pinion fitted and now the cable snapped. Its a newish cable. Think the problem with the cable is because it has to bend too sharply because of the Itg filter.
Have seen some 90 degree adaptors online but they are not cheap
#64 NZMini1275
NZMini1275
  • 227 posts
Posted 17 July 2017 - 05:40 AM
Ive managed to find a 90 degree speedo adaptor on ebay. Nos Smiths for a good price so that will solve the speedo cable problem
#65 Chris.Williams
Chris.Williams
  • 679 posts
Posted 18 July 2017 - 07:15 PM
What do it cost? Would you have been better off running a clubman/longer cable to route around your filter?
#66 NZMini1275
NZMini1275
  • 227 posts
Posted 19 July 2017 - 12:56 AM
$50 shipped from USA
My filter is hard back against the hole in bulkhead so the cable can't go down
It has to bend straight out of the back of the centre speedo to clear and this is where it's snapping because the radius is too tight
#67 NZMini1275
NZMini1275
  • 227 posts
Posted 24 July 2017 - 07:00 AM
New flywheel turned up today cant wait to get it fitted
#68 Chris.Williams
Chris.Williams
  • 679 posts
Posted 24 July 2017 - 07:51 AM
How lite did you go?
#69 NZMini1275
NZMini1275
  • 227 posts
Posted 25 July 2017 - 11:24 AM
It's the Med stage 1 super light
Flywheel is 3.65 kg and backplate is 1.25 kg and comes assembled and balanced
#70 NZMini1275
NZMini1275
  • 227 posts
Posted 31 July 2017 - 05:39 AM
Bit of an update
Fitted the 90 degree speedo adaptor. Plenty of clearance now so no more snapped cables
Have fitted the MED flywheel. This has made a huge difference to my engine. It revs so freely and smooth compared to the stock standard one which it replaced. I was a bit worried what it would be like after searching on here and reading everyone's views. All I can say is that with my setup it made a huge improvement with no downsides. Still idles fine.
Also had to fit a Med sticker haha
And now that the running in has been completed I had to raise the rev limiter.
Now I just need some time to go and play haha
#71 NZMini1275
NZMini1275
  • 227 posts
Posted 12 September 2017 - 05:43 AM
Car is all nicely run in and have tweaked the fueling. I now need to get it booked in for a run on a Dyno. I will be able to optimize the ignition advance curve using the amethyst. It will be interesting to see what values I end up with.
Also be nice to know what sort of torque and power its producing.
In other news I polished up the dashpot
Also got a few parts for my birthday
Got them all fitted up today
Today I also raised the rear ride height by 15mm and stiffened both front and back shocks. Was a bit low and was rubbing badly in the rear with no passengers haha.
#72 Vinay-RS
Vinay-RS
  • 2,097 posts
Posted 12 September 2017 - 06:48 AM
That's a beautiful engine and engine bay. Love the thermostat cover and that machined engine steady.
#73 NZMini1275
NZMini1275
  • 227 posts
Posted 14 October 2017 - 12:53 AM
Got some Matte black wrap to do the roof and also some bonnet stripes. What do you reckon?
#74 Vinay-RS
Vinay-RS
  • 2,097 posts
Posted 14 October 2017 - 06:40 AM
Looks good. The subtle contrast is cool.
#75 minimikej
minimikej
  • 347 posts
Posted 14 October 2017 - 01:38 PM
Hi, you got a link for this? I'm looking for the same.
