I have just finished reinstalling the head on my 1275 engine and as soon as I topped up the coolant got a leak from between the head and block at the front of the engine. It will leak at a steady rate from multiple places. I don’t know what went wrong. I cleaned the head and block thoroughly with cleaner and scotch-brite pads (nothing aggressive) and torqued the nuts to 45 Ft-Lbs in 3 steps (15-30-45) in the pattern called out in the manual. I used the head gasket from minispares in this kit GUG701186HS. A visual inspection showed it the same as the one removed. I’m a bit upset as I thought I was very diligent in the replacement of the gasket and I have done this type of repair on other vehicles before. Any ideas would be much appreciated.
