Could those in the know give me some help with the following please.
I have an 850 1979 Austin Morris Mini completely standard with an HS4 carb.
I had an isolated problem starting one day so I checked the plugs which were sooty. I cleaned them and it then started and ran fine. I made a note to self to check the mixture with my colour tune later in the week which I did which showed the mixture to be very rich. No surprise as the plugs were black.
I turned back the mixture nut to give a blue colour on idle using the colour tune, but as soon as I took it out it there was no power on pick up indicating too lean fuel so I kept adjusting the nut till it ran ok.
On checking the plugs they are once again sooty black, so now it seems I cannot get it to run normally without it being really rich. Using the spring needle to push up the dashpot on the carb to check mixture only gives correct results when the mixture is rich, so it seems a bit odd when the colour tune shows its way too rich.
I've checked the timing and that's correct.
Dashpot oil correct.
New plugs make no difference
As I can't seem to get the engine to run well unless the mixture is rich I'm thinking the carb and float bowl may need servicing, which would be my next thing to try, after I've 're checked the valve clearances, but wondered if I may be missing something obvious.
Any advice would be most welcome. Thank you.
