Air Leak At Servo
Guest_mark clark_*
Posted 02 March 2014 - 03:19 PM
Posted 02 March 2014 - 08:50 PM
If it's sucking in extra air then it's going to make the engine run too lean if it runs at all.
Guest_mark clark_*
Posted 02 March 2014 - 09:51 PM
Posted 03 March 2014 - 03:21 AM
A vacuum leak at the brake servo connection can make for a very hard to start engine and one that will only work with the choke on or throttle held open. A quick check is to remove the servo hose from the intake manifold. Plug or cap the connection on the manifold to make sure it is sealed, then take the car for a short drive. If the engine runs better you'll know the air leak is responsible.
The servo is not necessary for the brakes to work, it just reduces the amount of pedal effort. During your test drive, if you notice no difference in braking effort, it indicates that your servo has probably had the vacuum leak for quite a while and you've gotten used to the increased effort.
Guest_mark clark_*
Posted 03 March 2014 - 02:39 PM
Posted 03 March 2014 - 02:45 PM
Guest_mark clark_*
Posted 04 March 2014 - 05:36 PM
Guest_mark clark_*
Posted 07 March 2014 - 12:45 PM
