Cg13De Micra Powered Mini
39 replies to this topic
#31 l_jonez
l_jonez
  • 1,453 posts
Posted 01 June 2014 - 11:44 PM
A pre 96 ( I think)Micra will be non Nats and mechanical speedo drive.
#32 BradleyRogerson
BradleyRogerson
  • 94 posts
Posted 02 June 2014 - 10:27 AM
so i should just stay away from nats?
#33 l_jonez
l_jonez
  • 1,453 posts
Posted 02 June 2014 - 05:08 PM
Personally I would but if you where to integrate it into the mini it would provide a decent anti theft solution
#34 BradleyRogerson
BradleyRogerson
  • 94 posts
Posted 02 June 2014 - 06:02 PM
i was thinking that but i wouldnt be able to use mini clocks then would i?
#35 BradleyRogerson
BradleyRogerson
  • 94 posts
Posted 02 June 2014 - 06:04 PM
also sorry for hijacking the thread guys i did post my own but didnt get any replies and i didnt know where to turn  :shy:
#36 l_jonez
l_jonez
  • 1,453 posts
Posted 02 June 2014 - 07:09 PM
You can fit a mechanical speedo drive to the box and retain the cable.
Edited by l_jonez, 02 June 2014 - 07:09 PM.
#37 BradleyRogerson
BradleyRogerson
  • 94 posts
Posted 02 June 2014 - 07:40 PM
but to fit nats surely id need to use the micra clocks aswell? wont they be programmed to the ecu and decoder ring ect?...
#38 l_jonez
l_jonez
  • 1,453 posts
Posted 02 June 2014 - 08:25 PM
I don't think the clocks are involved in the Nats system. The Micra forum would be the place to ask.
#39 jonot2008
jonot2008
  • 26 posts
Posted 07 June 2014 - 02:36 PM
nope, if you have a nats ecu and loom all you have to do is tape the red piece out of micra key to the ring then hide it in the dash somewhere,
then you have pretty much the same thing as no nats. if you dont want to use micra clocks though i would at least find which wires are for the engine malfunction light and put a bubl in for it, also keep the diagnostic port. that way if anything goes wrong you can use the paper clip trip to read codes and find the problem.
even immobilizer codes show up, for example, if you try to start the engine without the transponder you will get code 144. (google micra paper clip) very handy if the engine wont start when its all in the car
#40 BradleyRogerson
BradleyRogerson
  • 94 posts
Posted 07 June 2014 - 05:47 PM
sweet! cheers the the info guys  :D
