Cg13De Micra Powered Mini
Posted 28 February 2014 - 09:10 AM
Posted 28 February 2014 - 10:33 AM
Posted 28 February 2014 - 11:09 AM
Posted 03 March 2014 - 03:36 PM
Cool
Get some more pics
Posted 10 March 2014 - 05:32 PM
Sorry took so long....been so busy!
Anyhow...here are a few more pictures (dirty black & yellow painted cam cover is before engine rebuild...nice clean silver after)
Posted 11 March 2014 - 11:38 AM
Posted 11 March 2014 - 02:02 PM
Posted 11 March 2014 - 06:40 PM
Posted 11 March 2014 - 07:57 PM
Excellent
Those pics are helpful the question I am stuck with on mine is the ground clearance do your subframes stick down fairly close to the ground?
Is that why you have modified the support going under the sump?
Posted 11 March 2014 - 08:39 PM
Just measured (from tie rod bolt hole to lowest point (sump of mini/rails of micra subframe) against a standard mini. The micra has about 20 mm less ground clearance than the normal mini.
But...the lowest point on the normal mini is the sump which wouldn't be good to whack into the ground, the micra mini's lowest point is the subframe rails. I'd much rather dig up some tarmac with some beefy subframe rails than with my sump...
By the way the paint that's scraped off the subframe rails isn't from bottoming out haha....its from dragging the subframe/engine under the mini to fit!!!
Posted 12 March 2014 - 09:17 AM
Posted 18 March 2014 - 03:37 PM
Man the more I see on this the more im liking it. Did you buy the subframe or make it? I would really like to see more of the build.
Got a million questions now...
has there been any bulkhead modifications?
How are the drive shafts connected, assuming its all mini stopping gear hubs, caliper etc?
Are you using any Nissan ecu stuff?
And on and on and on... lol
Like
Are there any tuning possibilities with the engine?
And on and on LOL!
Seriously though I am very tempted with this and im at a stage in my SPI rebuild where I can make changes easily enough...
Posted 18 March 2014 - 03:40 PM
there are several Micra build threads in this section you know http://www.theminifo...orum/167-other/
Posted 18 March 2014 - 07:08 PM
