crf150,
If you have copper and cupro-nickel side by side, you can tell them apart easily. Not so easy if you only have one. When clean and polished, copper is reddish-pink, and dulls down to a brownish red after a while, but kunifer, although pink, has a hint of grey, and tends to be duller. Bend them, copper is soft, and soom work-hardens, then breaks, if you bend it too often. It requires only light force in the flaring tool. Kunifer is much stiffer, and harder to flare.
But if the pipe was sold for automotive use, it "should" clearly state on the packaging what it is and what specifications it meets. If not, whoever supplied it is a cowboy, not following proper QA procedures. Not surprising....
