Bmw Mini Tappet Noise
13 replies to this topic
#1 Philcooper
Philcooper
  • 71 posts
Posted 27 February 2014 - 12:53 PM
Hi Guys. 2004 Mini Cooper FSH etc. some mornings when I start it up there is a Tappet rattle for a couple of minutes then it goes away. Is thus normal? Mileage is 62000
#2 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 27 February 2014 - 01:02 PM
Yes, that is normal. Most engines will sound tappetty when they're cold. As the engine heats up and the components expand, the noise will go away.
Completely normal :)
#3 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 27 February 2014 - 01:13 PM
Couple of minutes? Are these engines timing chain?
#4 HarrysMini
HarrysMini
  • 3,352 posts
Posted 27 February 2014 - 01:29 PM
Yes they are.
#5 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 27 February 2014 - 01:31 PM
Ive had cars with rattly chains before, that lasts a couple of mins from cold.
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 27 February 2014 - 02:39 PM
My mates JCW Cooper S does exactly the same then once warmed up its fine. A lot of cars with hydraulic followers do this. I had two 16 Valve Calibras and both did the same thing.
One was under warranty and when I had a chat to the chief service engineer he said it was very common.
#7 midridge2
midridge2
  • 1,794 posts
Posted 27 February 2014 - 02:52 PM
Yes, we have had 2 from new and they were both tappety till they warmed up.
#8 jaydee
jaydee
  • 8,565 posts
Posted 27 February 2014 - 03:33 PM
Flush engine oil, galleries are blocked by sludge, typical on engines with BMW scheduled maintanance.
#9 minisilverbullet
minisilverbullet
  • 3,799 posts
  • Name: Craig
Posted 27 February 2014 - 04:06 PM
I had a loud tappet  noise on my 3 series, changed to a BMW approved oil, it the noise certainly reduced.
As said though the hydraulic lifters are noisy at start up.
#10 The Principal
The Principal
  • 763 posts
Posted 27 February 2014 - 06:55 PM
I have a BMW Cooper S and spend some time on the Mini2 Forum, there are known faults on the BMW timing chain worst case scenario is a snapped chain. Have a read up on the BMW Mini forums and get that looked at soon.
http://www.mini2.com
#11 HarrysMini
HarrysMini
  • 3,352 posts
Posted 27 February 2014 - 08:07 PM
I think you'd know if you had a snapped chain, it would be doing more than a slightly louder tappet noise.
#12 mini13
mini13
  • 3,810 posts
Posted 27 February 2014 - 09:25 PM
these engines have rockers with hydraulic tappets in, these can get a bit noisy when cold after the engine has racked up some miles... also there is a timing chain tensioner that normally needs changing at about 100,000 miles, if this is dicky it could make it rattle a bit.
#13 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 27 February 2014 - 09:46 PM
The timing chain issues are for the PSA/BMW unit ( Prince ) . There are documented issues regarding " death rattles".
The OP states he has an 04 car which has the Tritec Chrysler engine. These engines should be quiet. If its noisy then I would say there is an issue somewhere.....
#14 HarrysMini
HarrysMini
  • 3,352 posts
Posted 27 February 2014 - 10:12 PM
Not necessarily. Our R53 and plenty others I have heard rattle a bit on a cold startup. As I said above, this is usually completely normal. Obviously, if it is continually tappetty, then there probably is an issue, however this isn't the OP's case.
