I know I am probably going to get a few different answers for this but what is the ideal way to prime the oil pump before fitting? I have heard of the following choices:
1. Use engine oil.
2. Use engine build lubricant.
3. Use Vaseline.
The reason I am asking is because once the engine is built it is going to be a while before it's used and also I haven't sent my gearbox off yet so it might be a while before everything is together. I don't want to fill the pump with oil only to have it all drain out without my realising, so it then wrecks my new engine when I start it up.
