Hi,
I started building my 7 port engine and i m having a problem.
I fitted the ARP main bolts and a new mini spares center strap.
ARP bolts must have a tight torque 85lb according to the manual included and minispares center strap bolts have a tight torque of 65lb. i tight them according with this spec and my crank doesn't rotate. i change the arp studs and fitted the standard ones and tight them all with 65lb and the crank rotates excellent. there is no problem with the crank or anything else. i m sure is the difference on the tighting torque.
how can i solve my problem since i want to fit the ARP bolts?
