Hi I have a split CV boot which I need to replace, what's the general opinion on stretchy cv boot kits or should I just do the job properly and fit a normal replacement CV Boot :)
Many thanks
Dan
Posted 25 February 2014 - 10:34 AM
Many thanks
Dan
Posted 25 February 2014 - 10:35 AM
Do it properley fit a replacement one peice boot.
Posted 25 February 2014 - 10:38 AM
thought so ill pick one up this weekend
oh and thanks for the reply :)
Edited by danny, 25 February 2014 - 10:39 AM.
Posted 25 February 2014 - 08:27 PM
Posted 25 February 2014 - 09:35 PM
as above you might need a new CV.........
Posted 25 February 2014 - 09:36 PM
Do it right, it only takes an hour.
Posted 25 February 2014 - 09:50 PM
If it's been open for more than a few miles I'd be tempted to flush the grease out and repack it with fresh. It's a messy job but doesn't take long and it might save you doing the job twice.
Posted 25 February 2014 - 09:57 PM
Should indeed proper regrease, but as I already said : when it waas open for too long it is probably : byebye cv..
Posted 25 February 2014 - 10:53 PM
i have used stretchy boots on loads of cars, but not on minis where the c.v comes off the end so easily anyway.
Posted 27 February 2014 - 02:42 AM
They come off most cars just as easily. I have never seen the need for a stretchy boot, on every FWD car that I have owned, which was 3 Minis, 1 Cavalier, 1 Astra, 1 Maestro and 1 Focus. The Minis, at least 2 of them, did the highest mileages, and needed new CVs a couple of times, but with all the others I was fortunate in only needing boots and grease every time. I did a few cars for friends too, I think one or two VWs and can't remember what else, but they were all fairly similar.
I have yet to see a CV that is not held on in the same way as in the Mini, with a spring clip, and in many cases the hub comes off without a ball joint splitter, which makes the job easier than the Mini.
In some of thses cars, particularly the Vauxhalls, the inner pots or tripode joints have an end stop, so that when you give the shaft a good tug, the inner member acts on it like a slide hammer and yanks the joint out of the diff with no fuss or bother. One of the others, I forget which, had bolted flanges at that end, also easy.
Posted 27 February 2014 - 04:37 AM
I've purchased the stretchy type boots for use on a Pajero - they were just fine, saved a lot of work.
Posted 27 February 2014 - 10:44 AM
Use genuine unipart CV boots, the cheap alternatives dont last long.
If a boot lasts only a few miles i call it false economy.
Posted 27 February 2014 - 11:04 AM
