Hi guys im currently building up a turbo engine and need abit of advise on what cam shaft to run. the engine spec is a+ block, 1293, omega cast pistons with the 10cc dish, balanced lightened a+ rods , arp rod bolts, 6581 crank ,lightened flywheel, rts clutch, steel center strap, turbo oil pump, opened up cylinder head, bronze guides, 36 inlet 32 exhaust, double springs, standard t3 turbo, big bore down pipe, motorbike can, pajero intercooler, and megajolt ignition. med 1.5 roller rockers, i plan on running about 12-15 psi boost, and the car will be used just for shows, club meets and track days. i have the choice of either a mg metro cam, kent 800 cam or standard.. your advise will be greatly appreciated
