1986 Mini Mayfair Complete Restoration.
10 replies to this topic
#1 minialf
minialf
  • 166 posts
Posted 18 February 2014 - 08:43 AM
I have had my mini for 6 years now and since I bought it, it has been off the road being stripped and completely restored. I have got reciepts totalling over £4,500 and im sure i have more that i havent added.
I was going to finish the mini but I have just bought a house and need the space really.
1986 MINI MAYFAIR WITH A 998CC ENGINE EXCELLENT FOR YOUNG DRIVERS OR EXPERIENCED DRIVERS AS THE INSURANCE IS REALLY CHEAP AND I HAVE KEPT THE ENGINE CLOSE TO STANDARD TO KEEP INSURANCE LOW. IT IS IN ALMOST COMPLETE CONDITION AND THE SHELL IS VERY VERY SOLID. I BOUGHT THIS CAR BACK IN SEPT 2008 AND HAVE PUT A LOT OF TIME AND EFFORT INTO BUT IT IS NOW TIME TO MOVE ON AS I NEED THE SPACE. WITH ALL THE PARTS I HAVE LISTED BELOW WHICH ARE NEARLY ALL NEW AND WITH THE CAR FINISHED WITH ALL THE PARTS WILL BE ALMOST SHOWROOM CONDITION.
Body Panels
THE FOLLOWING PANELS HAVE BEEN REPLACED
BOTH FRONT WINGS
GENUINE SCUTTLE PANEL
UNDER SCUTTLE CLOSING PANELS
COMPLETE BONNET
BOTH INNER SILLS (WHOLE LENGTH OF CAR, NOT JUST DOORWAYS)
OUTER SILLS ARE INCLUDED IN SALE
FRONT FLOOR PANELS
BOTH INNER WING FLITCH PANELS
BOTH A PANELS
COMPLETE BOOT FLOOR WITH BATTERY BOX INCLUDED
REAR VALANCE
CLOSING PANELS FROM VALANCE TO BOOT FLOOR
BOTH GENUINE REAR ARCHES
GENUINE ARCH TO FLOOR REINFORCEMENT BRACKETS
GENUINE REAR SEAT BACK TO ARCH REINFORCEMENT BRACKETS
SPARE WHEEL WELL BRACKET
REAR PARCEL SHELF
REAR PANEL COMPLETE WIDTH
ARCH REPAIR PANELS (FROM LOWER ARCH)
BOTH HEEL BOARD CORNER PANELS REPLACED 900
CROSS MEMBER REPAIR PANEL (DRIVERS SIDE)
GENUINE NEW JACKING POINTS (INTERNAL) BETWEEN INNER AND OUTER SILLS
X4 SMALL BRACKETS THAT ARE ALSO USED IN BETWEEN INNER AND OUTER SILL PANELS
REPLACEMENT THICK SEAT BELT MOUNTS ON INNER SILL
MODIFIED HEELBOARD BRACKETS TO FIT TO INNER SILL
COMPLETE ROOF SKIN- FROM SUNROOF TO SOLID ROOF
DRIVERS CROSS MEMBER REPAIR PANEL
BOTH A PANELS
TWO REPAIR PLATES TO THE REAR QUARTERS
X4 SMALL BRACKETS AND OUTER SILLS
External Body fittings
- NEW WINDOW RUBBER SEALS, INCLUDING - FRONT WINDSCREEN SEAL, REAR WINDSCREEN SEAL, FRONT DOOR TO BODY SEALS, REAR QUARTER CLOSING WINDOW SEALS AND BOOT CLOSING SEAL.
- NEW WINDOW WEATHER STRIPS IN CHROME
- NEW REGULATOR/ GLASS RUBBER
- SUNROOF WITH ALL PARTS REQUIRES REBUILDING
- NEW HEADLIGHT BOWLS INCLUDED
- WASHER BOTTLE CLEANED, PUMP CHECKED AND PIPE WORK REPLACED.
- CLEANED AND POLISHED BRIGHT WORK INCLUDING FRONT AND REAR BUMPERS, FRONT GRILLE SURROUNDS AND HEADLAMP SURROUNDING RINGS.
- NEW ROOF GUTTERING TRIM IN GLOSS BLACK WITH GUTTERING TRIM FINISHING CLIP
- NEW BONNET BADGE
- PRIVACY GLASS/ TINTED GLASS TO WITHIN LEGAL SPECIFICATION.
Engine/ Transmission
- FULLY REBUILT ENGINE INCLUDING ALL NEW SEALS AND GASKETS.
- STRIPPED, ACID CLEANED, JET WASHED, INSPECTED ALL PARTS THAT REQUIRE REPLACEMENT WAS REPLACED (SEE RECIEPTS) AND PRIMERED. AFTER PRIMER THE BLOCK AND HEAD WAS PAINTED IN ENAMEL LIME GREEN PAINT TO MATCH THE COLOUR SCHEME OF THE SUBFRAMES AND INTERIOR. THE GEARBOX, DIFFERENTIAL AND CLUTCH HOUSING AND COVER WAS THEN PAINTED WITH AN ENAMEL GLOSS BLACK PAINT TO MAKE IT STAND OUT FROM THE OTHER COMPONENTS USED. AFTER PAINTING WAS COMPLETE THE CYLINDER WAS THEN MEASURED AND CLEANED AND OILED. NEW HEAD GASKET ALONG WITH NUMEROUS OTHER SEAL WERE FITTED AND THE HEAD WAS REFITTED WITH NEW STUDS, WASHERS AND NUTS.
- POLISHED ROCKER COVER IS ALSO INCLUDED WITH POILSHED T- BARS THAT ARE EAILY RELEASED IF REQUIRED.
- BRAND NEW IN PACKET POLISHED/ CHROME DIPSTICK.
- ELECTRONIC IGNITION HAS BEEN FITTED TO THE ENGINE AS WELL SO IS MUCH MORE RELIABLE THAN STANDARD POINTS AND CONDENSER, THE DISTRIBUTOR WAS STRIPPED AND INSPECTED AND REBUILT READY FOR THE ENGINE.
- BRAND NEW SILICONE BLACK HT LEADS ALSO INCLUDED AND READY TO BE FITTED TO THE REBUILT ENGINE.
- ALTERNATOR HAS BEEN REPLACED BUT NOT YET FITTED (STILL IN BOX) FROM MINISPARES AS WHEN INSPECTED NEEDED A REFURBISHMENT SO I BOUGHT A NEW ONE TO BE FITTED ALONG WITH A NEW ALTERNATOR BELT.
- STARTER MOTOR REMOVED, STRIPPED AND INSPECTED AND EXCELLENT CONDITION. CLEANED AND PAINTED AND TESTED. REFITTED TO THE ENGINE READY FOR USE.
- MANIFOLD HAS BEEN SLIGHTLY PORTED SO THAT THE FLOW IS SLIGHTLY INCREASED AND STOPS REDUCTION WHEN AIR FUEL HITS MANUFACTURING FLAWS.
- SHOT BLASTED AND POWDER COATED BREATHER AND BLANKING PLATES FOR VALVE CHEST WITH NEW GASKETS TO BLOCK FACE.
- CLEANED AND PAINTED FUEL PUMP WITH A NEW REPLACEMENT GASKET AND SPACER PLATE.
- CLEANED AND PAINTED OIL FILTER HOUSING AND OIL FEED PIPE ALSO A NEW VERY EXPENSIVE BANJO BOLT AND WASHER SEALS FITTED.
- SHOT BLASTED AND POWDER COATED WATER PUMP PULLEY AND FAN PLATES.
- CLUTCH HAS BEEN REMOVED AND CHECKED AND ALL EXCELLENT CONDITION BUT I HAVE FITTED A NEW CLUTCH PLATE JUST FOR GOOD PRACTICE AS IT IS MORE COST EFFECTIVE.
- TIMING COVER STRIPPED, SHOT BLASTED AND POWDER COATED AND NEW MAIN SEAL FITTED.
- ALL NEW BOLTS MATCHED AND REPLACED WITH STAINLESS STEEL NUTS, BOLTS AND WASHERS WHERE REQUIRED.
- ALL NEW THROTTLE, CHOKE AND SPEEDO CABLES WITH APPLICABLE SEALS ETC.
- 1 1/2 " HS4 CARB STRIPPED AND REBUILT WITH SEAL SET AND GASKETS. (ALL GASKETS NOT USED I WILL KEEP IN A BAG FOR SPARES)
- SHOT BLASTED AND POWDER COATED SATIN BLACK FUEL TANK (LOOKS BETTER THAN WHEN THEY ARE NEW)
- LCB SPORT MANIFOLD CLEANED TO STAINLESS STEEL SHINE AND HEAT WRAPPED TO KEEP CLEAN.
- BRAND NEW STRAIGHT THROUGH LINK PIPE TO FIT FROM LCB MANIFOLD TO DUAL REAR EXIT SILENCER.
- POLISHED STAINLESS STEEL DUAL REAR EXIT EXHAUST WHICH HAS BEEN FITTED BUT FROM OTHER MINIS WITH THESE FITTED SOUND BRILLIANT.
- EXHAUST SYSTEM IS ALL NEW AND HAS BEEN POLISHED TO A VERY HIGH STAINLESS LOOK SO WILL LOOK GREAT WHEN FITTED TO THE CAR.
- ROOSE MOTORSPORT SILICONE HOSE SET FOR ALL COOLANT HOSES AROUND THE ENGINE BAY THEY LOOK REALLY GOOD WHEN THEY ARE ALL FITTED AND THEY ALL ARE FITTED WITH JUBILEE CLIPS THAT ACTUALLY FIT INSTEAD OF HAVING CLIPS THAT ARE 3 SIZES TOO BIG.
- REFURBISHED SATIN BLACK SIDE MOUNTED RADIATOR
- SHOTBLASTED RADIATOR AND ACCESSORY BRACKETS ETC.
- NEW THERMOSTAT STANDARD SETTING AT 88 DEGREES WITH A NEW THERMOSTAT HOUSING FITTED AS WELL.
Internal Body Fittings
A FULLY RE-TRIMMED INTERIOR THAT CONSISTS OF;
- TWO FRONT 40TH ANNIVERSARY HALF LEATHER STYLE SEATS WHICH ARE IN BLACK WITH LIME GREEN STITCHING AND PIPING
- A REAR BENCH AND REAR BACKREST ALSO IN THE SAME STYLE AND COLOUR SCHEME
- MATCHING DOOR CARDS WITH LIME GREEN PIPING AND STITCHING
- A SMOOTH BLACK HEADLINING WHICH INCLUDES HEADLINING STAYS ALL IN GOOD CONDITION
- A, B AND C PILLAR TRIMS WITH A REAR WINDOW TRIM ALSO ALL IN BLACK.
- GEARSTICK AND HANDBRAKE GAITOR IN BLACK WITH LIME GREEN STITCHING
- LIME GREEN ARCH LINING TRIMS FOR THE INTERIOR REAR ARCH
- BLACK BIN/ COMPANION LINERS FOR DOOR BINS.
- FULL BLACK LUXURY CARPET SET WITH MATCHING FLOOR MATS INCLUDING UNDER FLOOR INSULATION/ SOUND DEADNING
- LEATHER MOUNTNEY STEERING WHEEL
- CHROME INTERIOR HANDLES AND FIXTURES
- BOTH FRONT SUNVISORS ALSO RETRIMMED IN LIME GREEN/ BLACK WITH STITCHING IN LIME GREEN
- COMPLETE BLACK SEATBELT KIT INCLUDING ALL MOUNTING BRACKETS AND BOLT COVERS
THIS INTERIOR HAS BEEN RETRIMMED BY A MINI SPECIALISED CALLED RETRO RETRIMS, IT HAS DONE AN EXCELLENT JOB OF THE INTERIOR AND THIS IS ALONG WITH EVERYTHING ELSE FINISHES THE CAR PERFECTLY. THE INTERIOR COMPLETE COST ME JUST UNDER £800 WITH RECIEPTS TO PROVE IT. AGAIN WITH ALL THE OTHER EXPENSE THAT HAS BEEN SPENT ON THE CAR YOU ARE GETTING A REALLY GOOD DEAL.
Electrical
- STARTING AND CHARGING SYSTEMS HAVE BEEN REFURBISHED INCLUDING STAER MOTOR REFURBISHMENT, ELECTRONIC IGNITION STRIPPER CLEANED INSPECTED AND REBUILT, ALTERNATOR CHECKED AND REPLACED WITH A BRAND NEW UNIT, A NEW BATTERY TO STARTER MOTOR MAIN BATTERY CABLE ALONG WITH A NEGATIVE/ EARTH BATTERY CABLE ASWELL.
- WIRING LOOM HAS BEEN REMOVED FROM THE SHELL AND LABELLED READY FOR REFITTING AFTER PAINTED OR IF DESIRED RE-LOOMED.
- NEW IGNITION COIL WITH NEW HT LEADS AND POLISHED COIL COVER.
- WIPER MOTOR AND LINKAGE STRIPPED, CLEANED, INSPECTED AND REBUILT WITH ALL PARTS CLEANED/ PAINTED.
- BATTERY SUPPORT STRAP, RETAINING BAR AND COVER ALL NEW.
Brakes
- 2 PISTON PER CALIPER BRAKES, SHOTBLASTED AND POWDER COATED SATIN BLACK. NEW PISTON SEALS FITTED WITH RINGS AND ALL NEW PISTONS THEMSELVES, ALSO BLEED NIPPLES AND BRIDGING SEALS.
- BRAND NEW DISC BRAKES FOR THE FRONT STILL IN BOXES NOT OPENED.
- GREEN STUFF BRAKE PADS WITH NEW BRAKE PINS AND RETAINING PLATES.
- SHOTBLASTED AND POWDER COATED REAR BRAKE DRUMS
- BRAKE SHOES AND SHOE SPRINGS ALSO KEPT IN A BOX READY TO FIT.
- BACKING PLATES FOR REAR DRUMS SHOTBLASTED AND POWDER COATED WITH WHEEL CYLINDER ADJUSTERS AND SCREW FITTED
- REAR WHEEL CYLINDERS WITH BRAKE PIPES ALSO INCLUDED.
- PEDAL BOX SHOTBLASTED AND POWDER COATED INCLUDING ALL PEDAL AND NEW BRAKE SWITCH FITTED.
- REFURBISHED BRAKE MASTER CYLINDER (YELLOW BAND CYLINDER) WITH NEW SEAL KIT FITTED
- SHOTBLASTED AND POWDERCOATED PDWA VALVE.
- NEW HANDBRAKE CABLES WITH SHOTBLASTED QUADRANTS AND ACCESSORIES.
Suspension
- ALL NEW GENUINE ROVER RUBBER CONE SET (FRONTS HAVE BEEN FITTED TO FRONT SUBFRAME) WITH REAR CONES STILL IN PACKETS.
- ALL SUSPENSION ALLUMINIUM CONES SHOTBLASTED AND PRIMERED THEN PAINTED IN ENAMEL LIME GREEN PAINT.
- UPPER ARMS ALSO SHOTBLASTED AND POWDERCOATED SATIN BLACK WITH NEW BEARING SETS, GREASE NIPPLES, DAMPER PINS, NYLON CUPS, WASHERS, NYLOC NUTS AND BOLTS ALSO FITTED (BASICALLY BRAND NEW REFURBISHED UPPER ARMS)
- LOWER ARMS AGAIN SHOTBLASTED AND POWDER COATED IN SATIN BLACK WITH NEW POLY BUSHES FITTED AND NEW NUTS AND BOLTS.
- TIE RODS ALSO SHOTBLASTED AND POWDERCOATED WITH ALL NEW BUSHES TO SUBFRAME AND NUTS, BOLTS AND WASHERS FOR FITMENT.
- NEW SUBFRAME/ LOWER ARM PINS ALSO SHOTBLASTED/ POWDER COATED SATIN BLACK AND NEW WASHERS AMD NYLOC NUTS FITTED.
Running Gear
- DRIVESHAFTS HAVE ALSO BEEN SHOTBLASTED AND POWDER COATED WITH BALLBEARING REMOVED, CLEANED AND REGREASED ALONG WITH BALL CAGES, INNER AND OUTER C.V POT JOINTS ALSO PACKED.
- ALL NEW C.V BOOTS FITTED AND AS ABOVE PACKED WITH HIGH PERFORMANCE GREASE.
- BOTH HUB FLANGES HAVE BEEN BLASTED AND POWDERCOATED TO MATCH ALL PARTS AND ALL STUDS HAVE BEEN REFITTED.
- COMPLETE HUBS HAVE BEEN STRIPPED DOWN TO THE BODY CASING, THORUGHLY CLEANED, SHOTBLASTED AND POWDER COATED SATIN BLACK, NEW BEARINGS, RACES, INNER AND OUTER SEALS REPLACED, ALL BALL JOINTS REPLACED WITH X4 SHIM SETS INCLUDED IF REQUIRED, NEW NUTS BOLTS AND WASHERS WHERE REQUIRED AND BLEED/ GREASE NIPPLE REPLACED ALSO. BOTH HUBS HAVE ALSO BEEN PACKED WITH HIGH PERFORMANCE GREASE.
- THE REAR RUNNING GEAR/ TRAILING ARM SET UP HAS ALSO BEEN STRIPPED, CLEANED, SHOTBLASTED AND POWDER COATED AND STORED READY FOR REBUILDING THE REAR SUBFRAME.
- REAR WHEEL BEARINGS ALSO READY FOR REAR SUBFRAME/ TRAILING ARM REBUILD.
Steering
- FULLY STRIPPED AND BLASTED STEERING RACK, AGAIN PAINTED IN SATIN BLACK WITH REGREASED RACK GEAR AND NEW STEERING GAITORS FITTED (ALSO PACKED WITH GREASE) ALONG WITH BOTH NEW TRACKROD ENDS AND NUTS AND BOLTS TO CONNECT TO STEERING PINS.
- SHOTBLASTED AND POWDERCOATED STEERING HUB PINS WITH NEW HT BOLTS AND LOCKING TABS FOR WHEN FITTED ALSO HAS ALL 4 NEW SPACER RINGS FOR FITMENT TO HUBS
- 2 NEW U BOLTS WITH NUTS AND WASHERS.
- 2 DAMPING SHEETS TO BE FITTED WITH U BOLTS TO STEERING BODY BRACKET TO STOP NOISE
- NEW SEAL FOR RACK TO BODY CONNECTION TO STOP WIND NOISE WHEN DRIVING
- ALSO INCLUDED IS A VARIETY OF SHOTBLASTED PARTS TO REFIT THE STEERING COLUMN TO THE DASH/ INTERIOR.
 Subframes
- FRONT SUBFRAME HAS BEEN FULLY STRIPPED TO JUST THE BARE FRAME, SHOTBLASTED AND POWDERCOATED TO STOP ANY RISK OF RUST/ CORROSION. IT HAS BEEN FITTED WITH ALL NEW BUSHES AND MOUNTINGS TO BE FITTED IN THE ENGINE BAY. THE REBUILT
SUSPENSION, BRAKES, RUNNING GEAR AND STEERING COMPONENTS ARE ALL READY TO BE FITTED TO THIS FRAME (THIS SET UP IS WORTH £1591 ALONE FROM SOMERFORD MINI AND MINISPARES). WHEN THE SUBFRAME HAD BEEN POWDER COATED THEN THE REBUILT ENGINE HAS BEEN FITTED WITH NEW ENGINE MOUNTINGS, STEADY BUSHES AND BRACKETS AND LOOKS EXCELLENT. WHEN THE RUNNING GEAR, SUSPENSION, BRAKES AND STEERING COMPONENTS HAVE BEEN FITTED TO THIS SUBFRAME AND ENGINE PART YOU WILL BE HOLDING A VERY SMALL FORTUNE!
- THE REAR FRAME HAS ALSO BEEN SHOTBLASTED AND POWDER COATED AND ALL NEW SEALS/ RUBBERS HAVE BEEN FITTED ASWELL. ALTHOUGH I HAVENT COMPLETELY REBUILT THE REAR FRAME IT IS EASIER THAN THE FRONT AS YOU ONLY HAVE TRAILING ARMS (WHICH HAVE BEEN POWDERCOATED ALREADY) AND HUBS TO REFIT TO THIS FRAME ALONG WITH REAR TRUMPETS AND CONES THAT ARE ALSO READY AND DAMPERS THAT ARE A 5 MINUTE JOB (WHICH ARE INCLUDED)
Wheels/Tyres
- SHOTBLASTED AND POWDERCOATED SATIN BLACK 12 INCH MINILITES WITH TYRES INCLUDED
- CHROME WHEEL BOLTS X 16
- A SPARE WHEEL WILL ALSO BE INCLUDED IN THE SALE IT IS THE SAME AS THE 12" BLASTED SATIN BLACK ALLOYS MINILITES.
I HAVE OVER £3500 OF RECIEPTS AND THAT DOESNT INCLUDE SHOTBLASTING AND POWDER COATING COSTS, BUYING THE CAR, BUYING THE JIG THE MINI IS ON, PRIVACY GLASS/ WINDOW TINTING, MOUTNEY LEATHER STEERING WHEEL, LCB EXHAUST MANIFOLD AND HEAT WRAPPING, WHEEL ARCH TRIMS, SUNROOF AND ALL RELATED PARTS, 12" MINILITES, PARCEL SHELF SHAPED STEALTH WOOD, ROOSE MOTORSPORT SILICONE HOSE SET IN LIME GREEN AND PROBABLY A FEW MORE PARTS THAT I CANT REMEMBER. THE CAR WITH ALL PARTS LISTED OWES ME JUST UNDER £6,000, IT WOULD MAKE A REALLY GREAT CAR FOR A REAL ENTHUSIAST OR SOMEONE THAT WANTS A PROJECT THAT THEY CAN MAKE SOME MONEY ON.
EXTRAS
I ALSO HAVE SOME EXTRA PARTS THAT CAN BE SOLD FOR AN EXTRA PRICE ON TOP OF THE AUCTION WHICH ARE AS FOLLOWED...
- BOOT BUILD KIT FOR COVERING UP THE FUEL TANK AND SPARE WHEEL IN THE BOOT, MAKES THE BOOT A LOT TIDIER.
- ILLUMINATED DASH CLOCKS WHICH CAN CHANGE THE DASH COLOUR FROM IF I CAN REMEMBER A BLUE TO GREEN GLOW.
- SOUND SYSTEM WHICH INCLUDES JBL DOOR SPEAKERS, 6X9 SPEAKERS, TWEETERS, SUB WOOFER AND AMPLIFIER AND WIRING KIT WHICH ALL COST ME £300.
- I HAVE A FULL ROOF SKIN THAT I WAS GOING TO FIT INSTEAD OF THE SUNROOF BUT IT IS AN OPTIONAL EXTRA IS YOU DESIRE A SOLID TOP ROOF SKIN INSTEAD OF A SUNROOF.
- HEADLAMP PEAKS IN STAINLESS STEEL
- ANGEL EYES WITH WHEEL RINGS AND CAN BE FITTED WITH A HID KIT
- STAINLESS STEEL TREAD PLATES FOR DOOR STEPS WITH MINI EMBOSSED/ ETCHED INTO THEM.
- 1275 GT SYTLE SIDE STRIPS IN BLACK WHICH SAY 'MINI SPECIAL'
- REEL OF BRAKE PIPE FOR FITTING NEW BRAKE PIPES TO THE VEHICLE.
HERE ARE A FEW RECEIPTS FOR THE REBUILD THAT I HAD IN MY EMAILS BUT LIKE I SAID I HAVE GOT A HARD COPY OF ALL OF THE PARTS PURCHASED AND TOTALS OVER £3500.
Part code Description Quantity Unit price   Amount TAM1062 TRIPLE GROOVE INLET VALVE 27.8mm LEADFREE (998 cc) 1 £6.00   £6.00 14A8336 JACKING HOLE SUPPORT BRACKET R/H 1 £1.75   £1.75 14A8375 JACKING POINT L/H and CROSS MEMBER EXTENSION REPAIR 1 £11.45   £11.45 14A8374 JACKING POINT R/H and CROSS MEMBER EXTENSION REPAIR 1 £11.45   £11.45 2A715 BLOCK BOLT FOR OIL PIPE 1 £13.00   £13.00 GTS104 THERMOSTAT 82 DEGREE 1 £2.59   £2.59 C-AHT288 CYLINDER HEAD WASHER SET (10) 1 £3.00   £3.00 GFK1126 SPRING WASHER 3/8X11/16 2 £0.12   £0.24 2A4328 FRONT SUSPENSION TIE BAR CUP WASHER 2 £0.51   £1.02 GFK5184 SETSCREW 5/16 X 3/4 UNF 4 £0.27   £1.08 51K1193 STANDARD CYLINDER HEAD RETAINING NUT 10 £1.00   £10.00 ADU5738 DIFF OUTPUT SHAFT OIL SEAL 2 £0.80   £1.60 GFK3323 LOCK NUT 3/8 UNF NYLOC 4 £0.12   £0.48 CAM151 HEAD STUD BLOCK TO HEAD SHORT 4 LONG UNC 3/8 3 £2.15   £6.45 AED172 COPPER SUMP PLUG AND BLOCK WASHER 2 £0.79   £1.58 GFK3224 NUT NYLOC 7/16 UNF 2 £0.16   £0.32 GFK3212 NUT PLAIN 5/16 UNF 2 £0.08   £0.16 21A1882MS LOWER ARM BUSH UPGRADE BLACK POLY TYPE 2 £1.30   £2.60 SBK1 ENGINE STABILISER 4 BUSH KIT WITH SC2 PLASTIC INSERTS 1 £1.30   £1.30 GFE166 OIL FILTER SPIN ON TYPE 1973 TO 1996 (MANUAL ONLY) 1 £2.25   £2.25 GFK1125 SPRING WASHER 5/16 X 19/32 2 £0.10   £0.20 88G479 SPARE WHEEL CLAMP FLOOR BOSS IN BOOT 1 £6.75   £6.75 6K638 WASHER FOR BLOCK DRAIN PLUG (53K2853) 1 £0.53   £0.53 14A9552 FLOOR TO SILL REINFORCEMENT SLINGER BRACKET RH 1 £3.95   £3.95 14A9553 FLOOR TO SILL REINFORCEMENT SLINGER BRACKET LH 1 £3.95   £3.95 Net goods subtotal:   £93.70 Delivery type: Courier - Standard   £7.50 Net order subtotal:   £121.72 Total VAT:   £24.34     Order total:   £146.06
Part code Description Quantity Unit price   Amount 114713 CALIPER PISTON 2 dia FOR 8.4 DISC 12 WHEEL 4 £7.00   £28.00 11K9181 BRAKE PIPE CLIP FOR FRONT SUBFRAME 8 £0.49   £3.92 12A1176 BUSH TAPPET CHEST COVER 2 £1.00   £2.00 12A2035 GASKET OIL FILTER HOUSING SPIN ON FILTERS ONLY 1 £0.36   £0.36 12G103 THERMOSTAT HOUSING MOST MINIS UNTIL 1990 1 £6.50   £6.50 13H2934 CLUTCH OIL SEAL UPTO 1992 1 £2.15   £2.15 13H3735 BRAKE LIGHT SWITCH FLOOR TYPE 1976 ON 1 £3.36   £3.36 17H7679 CALIPER SEAL INNER 8.4 TYPE CALIPER (8.4 CALIPER, 2 POT) 2 £0.75   £1.50 18G9027MS CV JOINT GAITER KIT UNIVERSAL FOR ANY MINI 2 £1.95   £3.90 1E5537 ACCELERATOR RETURN SPRING 1 £2.31   £2.31 21A1882MS LOWER ARM BUSH UPGRADE BLACK POLY TYPE 2 £1.30   £2.60 21A2553 STEERING RACK ANTI FRICTION STRIP 2 £0.65   £1.30 21A2599MS SUBFRAME MOUNTING FOR REAR OF THE FRONT FRAME 2 £2.38   £4.76 21A30 STEERING RACK TO BODY SEAL 1 £0.36   £0.36 21A423MS SUSPENSION KNUCKLE JOINT NYLON CUP ONLY 2 £0.82   £1.64 22A1613 LOCKNUT (GAE191)3/8 unc 1 £0.45   £0.45 22G2595 SELECTOR FORK ROLL PIN - ROD CHANGE 2 £0.82   £1.64 2A7327 SEAL DUST EXCLUDER RADIUS/UPPER ARM 2 £0.62   £1.24 2K5377 STEERING ARM LOCKTAB 2 £2.10   £4.20 31B447 SEAL UNDER ROD CHANGE SELECTORS TO GEAR CASE 1 £0.41   £0.41 31G279 MASTER CYLINDER GASKET SINGLE LINE 1 £0.63   £0.63 37H4229M VACUUM PIPE WITH CONNECTORS 1 £2.40   £2.40 37H4836 WIPER MOTOR STAINLESS STEEL STRAP WITH SEAL 1 £4.75   £4.75 3H2428 BLEED NIPPLE 3/8 UNF THREAD 3 £1.20   £3.60 42B413 MATALASTIC ROD CHANGE BUSH 2 £8.76   £17.52 442001 DAMPER KAYABA FRONT STD SHOCK ABSORBER 2 £12.32   £24.64 53K1031 TIE BAR BOLT 2 £0.70   £1.40 5L1137 BRAIDED ENGINE EARTH STRAP 1 £3.00   £3.00 6K431 OIL PRESSURE RELEASE VALVE COPPER WASHER 1 £0.35   £0.35 88G561 TIMING COVER OIL SEAL ALL PRE 1992 1 £1.80   £1.80 AAU2866 VERTO RELEASE BEARING RETAINING O RING 1 £0.60   £0.60 ADU5065 Choke cable Clip for SBF10027 1 £1.87   £1.87 AJM1250MS HEAD GASKET SET 850/997/998/1100 ALL SMALL BORE INC A PLUS 1 £7.25   £7.25 AJM202MS BLOCK GASKET SET SMALL BORE PLUS COOPER S 1 £9.69   £9.69 AUC8459 CARB GASKET SU FLOAT CHAMBER 1 £0.43   £0.43 BHM7012 POT JOINT GAITER KIT, NON GENUINE 2 £3.50   £7.00 BHM7113 STEERING RACK GAITER KIT,PAIR 4.5 LONG 1 £4.50   £4.50 BTA249MS FRONT HUB NUT METRIC 34mm, DISC CV TYPE 2 £2.20   £4.40 CAM5969 GROMMET FOR HEATER or CHOKE CABLE 1 £1.50   £1.50 CDU1563 O RING ON ROD CHANGE SHAFT BUSH 1 £0.85   £0.85 CHM373 HEATER CONTROL CABLE 1969 TO 1988 1 £6.50   £6.50 C-STR628 TIE BAR BUSH - HARD RUBBER SINGLE BUSH ONLY 4 £0.75   £3.00 FAM2764 BUMP STOP WITH SINGLE BOLT FIXING ON S/FRAME 1976on 2 £4.50   £9.00 FAM6924 STEERING ARM DOWEL 4 £1.85   £7.40 GAE191 REVERSE LIGHT SWITCH ROD CHANGE 1 £6.50   £6.50 GBD90806MS BRAKE DISC 8.4 NON VENTED AS USED IN MSSK014 KIT 2 £9.25   £18.50 GBK1026 BRAKE PAD CLIPS AND PINS MINI 84 ON EXCEPT VENTED 1 £4.03   £4.03 GCB10825 FAN BELT COGGED 1980on EXCEPT TWIN POINT 1 £3.50   £3.50 GCP271AF CLUTCH PLATE VERTO 180mm 1 £27.19   £27.19 GFK3322 5/16 UNF NYLOC NUT 4 £0.11   £0.44 GFK5191 BOLT 3/8 X 1 UNF SETSCREW 2 £0.20   £0.40 GHK1140MS HUB KIT FRONT WITH SEALS and SPLIT PIN NON GENUINE 2 £14.25   £28.50 GMC1008 CLUTCH MASTER CYLINDER PLASTIC BODY 1 £37.92   £37.92 GPS133 OIL PRESSURE SWITCH,MINI AND METRO 1 £3.90   £3.90 GRK4001 CLUTCH SLAVE REPAIR KIT VERTO FITS GSY117/8 1 £4.25   £4.25 GRK5008 CALIPER SEAL REPAIR KIT 12 WHEEL genuine 2 £4.65   £9.30 GSD415 48 SPEEDO CABLE 76-90 1 £8.25   £8.25 GSJ166MS MINI BALL JOINT KIT 2 £6.30   £12.60 GSJ734MS TRACK ROD END JOINT MINI/METRO NON GENUINE 2 £4.00   £8.00 GTG101MS ORIGINAL SHAPE THERMOSTAT HOUSING GASKET 1 £0.28   £0.28 GTR101 TEMPERATURE TRANSMITTER 1970 ON 1 £4.00   £4.00 GUG705555GM GENUINE WATER PUMP GASKET 1 £1.10   £1.10 GUG705565GM SPEEDO PINION GASKET, 1 £1.61   £1.61 GUG705603GM FUEL PUMP SPACER BLOCK and GASKET 1 £6.14   £6.14 GXE2211 ALTERNATOR 45AMP NEW WITH PULLEY AND FAN OUTRIGHT SALE 1 £36.24   £36.24 KGE100050 SUBFRAME FRONT RUBBER UPPER ROUND CENTRE BOLT MOUNT 2 £2.96   £5.92 KGE100060 SUBFRAME FRONT LOWER MOUNTING RUBBER FOR CENTRE BOLT 2 £5.00   £10.00 LN10051 GREASE NIPPLE SWIVEL PINS - STRAIGHT (2 required per hub) 4 £0.95   £3.80 MSK001 UPPER ARM REPAIR KIT 2 £12.51   £25.02 MSSK050 GEARBOX ROD CHANGE ANTI OIL LEAK SEAL KIT 1 £4.25   £4.25 MSSK061 CYLINDER HEAD ANCILLARY STUD AND NUT KIT PRE 1990 1 £14.00   £14.00 NAM5645 WHEEL STUD (31mm) MINI 84 ON AND METRO 1 £1.50   £1.50 NAM7914 ACCELERATOR CABLE MINI HS2 AND HS4 ONLY 1 £2.45   £2.45 NAM9197 MASTER CYLINDER PLATE GASKET EARLY TYPE 1 £2.60   £2.60 NT608041 NUT PLAIN 1/2 INCH HALF NUT 2 £0.08   £0.16 RPS1416 ROD CHANGE GEAR LINKAGE ROLL PIN 1 £0.90   £0.90 SBK1 ENGINE STABILISER 4 BUSH KIT WITH SC2 PLASTIC INSERTS 1 £1.30   £1.30 SH505061 BOLT FOR BREATHER LLC10047 UNC 5/16 X3/4 LONG 2 £0.47   £0.94 UHN445 GREASE NIPPLE TOP ARM (45°) 2 £0.85   £1.70 XFH100460 REAR LENS TO LAMP BODY SEAL FOR ALL MK4 ON 2 £4.50   £9.00 Net goods subtotal:   £502.87 Delivery type: Courier - Standard   FREE Net order subtotal:   £502.87 Total VAT:   £100.57   Order total:   £603.44
Part code Description Quantity Unit price   Amount MS55L L/H OUTER SILL Mk3 ON - NON GENUINE 1 £11.04   £11.04 MS27L INNER SILL PANEL L/H NON GENUINE 1 £6.90   £6.90 TUK100320 IDLER NEEDLE ROLLER TYPE FOR A PLUS GEARBOX 1 £7.30   £7.30 Net goods subtotal:   £25.24 Delivery type: Courier - Standard   £7.50 Net order subtotal:   £32.74 Total VAT:   £6.55     Order total:   £39.29
Products
1 x FRONT FLOOR-NO INNER SILL-R/H (REPAN054) = £9.84
1 x FLITCH REPAIR PANEL-MK3 -L/H (REPAN069) = £8.99
1 x FLITCH REPAIR PANEL-MK3 R/H (REPAN068) = £8.99
1 x COMPANION BIN CLOSE PLATE & SEGMENT-SALOON-LH (14A6612) = £9.12
1 x COMPANION BIN CLOSE PLATE & SEGMENT-SALOON-RH (14A6611) = £9.12
1 x ARCH TO REAR SEAM REPAIR PANEL-SALOON-R/H (REPAN067) = £4.50
1 x FRONT FLOOR-NO INNER SILL-L/H (REPAN055) = £9.84
1 x ARCH TO REAR SEAM REPAIR.PANEL-SALOON-L/H (REPAN066) = £4.50
1 x SCUTTLE PANEL-FULL WIDTH (HMP441001) = £87.50
Sub-Total: £152.40
14A6609 Boot Floor To Wheel Arch 1 £6.61 £6.61
Support Bracket - RH, Genuine
14A6610 Boot Floor To Wheel Arch 1 £6.61 £6.61
Support Bracket - LH, Genuine
HMP441020/RH Rear Valance Closing Assembly 1 £23.00 £23.00
- Genuine, RH
HMP441021/LH Rear Valance Closing Assembly 1 £23.00 £23.00
- Genuine, LH
14A9559 Rear Wheel Arch Inner - 1 £41.69 £41.69
Genuine, LH
14A9558 Rear Wheel Arch Inner - 1 £41.69 £41.69
Genuine, RH
Subtotal: £142.60
Shipping (England Mainland - DHL - 24/48 Hr): £8.51
VAT: £26.47
Total: £177.58
THESE ARE JUST A FEW RECIEPTS I HAD TO HAND.
IF SOMEONE COULD HELP WITH WHAT ALL THIS WOULD BE WORTH IT WOULD HELP ALOT.
THANKS ALOT.
#2 Jakemorrismini
Jakemorrismini
  • 197 posts
Posted 18 February 2014 - 08:50 AM
Omg! How much work/money has been out into that car! Just makes you realise how much work goes into them!
#3 the_samkingdon15
the_samkingdon15
    formally known as samkingd0n
  • 644 posts
  • Local Club: I ride alone
Posted 18 February 2014 - 09:00 AM
any pictures man??
#4 minialf
minialf
  • 166 posts
Posted 18 February 2014 - 09:05 AM
yes i have a loads. ive go a few on me give me a min and ill put some up.
#5 minialf
minialf
  • 166 posts
Posted 18 February 2014 - 09:10 AM
having trouble....
Edited by minialf, 18 February 2014 - 09:12 AM.
#6 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 18 February 2014 - 09:12 AM
I'd break it, its probably the only was you'll see decent money back from it.
#7 minialf
minialf
  • 166 posts
Posted 18 February 2014 - 09:23 AM
how much do you think the shell is worth?
#8 minialf
minialf
  • 166 posts
Posted 18 February 2014 - 09:39 AM
would there be enough interest to break the project?
#9 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 18 February 2014 - 09:59 AM
The sunroof will limit the market for the shell really.
I'd also be tempted to chuck a quick coat of grey primer on it as well.
A good well restored shell could be a grand to the right person.
#10 minialf
minialf
  • 166 posts
Posted 18 February 2014 - 10:19 AM
no it did have a sunroof but ive put a solid roof on instead
#11 minialf
minialf
  • 166 posts
Posted 18 February 2014 - 10:21 AM
i was going to have it shotblasted and primered. do you think that would show its a solid shell?
