I have for sale a Clarke Pro-90 Mig welder.
Its been sitting unused and unloved in a garage for some time and will need some love and attention to sort it out.
The biggest issue with it is the torch, there is a tip in it but somebody decided to either drop it or cross thread the tip in place
it does go back in but i tried to fit a new tip but it will not go in. I would suggest a tap to clean the thread up to get it back to a useable state.
The drive wheel is a little bit rusty and could do with a clean up as well. It does work and does feed but there is a little stutter when feeding the wire through.
It does come with a 5kg spool of 0.6mm wire and is approx 3/4's full. There is a large hose adapter fitted as well but if you want to use the throw away bottles the regulator is in the case.
So all in all with a little bit of work this welder would suit somebody who wants to start welding their mini.
It does weld as i have actually tried it but i cannot verify if the gas hose is damaged at all.
So its £50 no offers and it will need to be picked up from Stone Cross, Eastbourne.
