Fly Off Or Hydraulic Hand Brake ?
45 replies to this topic
#1 miniboy94
miniboy94
  • 64 posts
Posted 12 February 2014 - 09:40 PM
hi guys again iv been looking into a hydraulic hand brake for my mini as the cable one is really poor lol i found all the stuff i think i need but im worried that if i plum it strait into the back brake lines with anther t-piece will it work or will it want to lock the front wheels up to ? i dont want to end up fitting one and finding out the hard way and crashing :/ or should i just stripp down all my rear brake and by some rally shoes, and just run a flyoff hand brake to make it u-turn better ?
help would be great thanks ben
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 12 February 2014 - 09:43 PM
Does the car need to be road legal mate?
Also, are the rears properly adjusted and handbrake quadrants free and lubricated?
#3 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 12 February 2014 - 09:44 PM
Do you need the car to be road legal and pass an MOT?
#4 smudger068
smudger068
  • 344 posts
Posted 12 February 2014 - 09:48 PM
Leave the cable operated one in for the Mot
Plumb in a cylinder inline to the rear brake feed and put in next to the gearlever or original handbrake n jobs a goodin'
Google it possibilities are endless
#5 miniboy94
miniboy94
  • 64 posts
Posted 12 February 2014 - 10:01 PM
i can get the car to pass a mot any way from a mate as my emmissons are quite bad and yeah everything is free i fitterd all new cable rear alloy quadrants shoes mini fin drums trying to make it better still no good so i fort of going hydraulic ? i was thinging of leaving the normel cable one on to if i can get away with it but i the kit i was buying has an external res for the fluid and was just thinking of pluming one into the back rear brake pipes if that will work ? and thanks guy for help :) sorry about spelling
#6 Down&Out
Down&Out
    The King Of Retro Cool
  • 4,852 posts
Posted 12 February 2014 - 10:14 PM
So what you're saying is that your car doesn’t legally meet the minimum road legal parameters?
The mini handbrake isn't that bad, the one in my Dolomite is worse, you can drive with that on even when its fully adjusted.
A properly adjusted handbrake on any of my minis has always been fine, I don’t see why you'd want all the arseing around trying to fit a hydraulic one.
#7 Carlos W
Carlos W
  • 10,114 posts
Posted 12 February 2014 - 10:17 PM
And him and his mate could go to prison if someone is killed or injured!
#8 miniboy94
miniboy94
  • 64 posts
Posted 12 February 2014 - 10:40 PM
he only passes it as long as i take it back proving that i have sorted it out as in if he finds a ball joint with a split rubber he will advice it as long as i sort it out with in 24 hours of leaving him basecly i get a pre mot before to make sure ball joint and other bits and bobs are all leggal,but to be fair its only my emission that i sturggle with but going dyno this mouthe so il be good to go :) and im trying to turn it into a rally car down and out :) that why i would like hydrolic hand brake
#9 69k1100
69k1100
  • 376 posts
Posted 13 February 2014 - 05:23 AM
The point is hydraulic handbrakes aren't legal in a road car. If you want to go hydraulic then don't bother registering it. If you have a line locker/hydraulic handbrake and cable handbrake side by side it still won't be legal if the cable handbrake doesn't work.
#10 69k1100
69k1100
  • 376 posts
Posted 13 February 2014 - 05:24 AM
If you're mate passes you then good luck. You get caught you and your mate will go down.
#11 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 13 February 2014 - 08:55 AM
grandad racers have been hand brake turning minis since they were boy racers
i'm guessing if yours isn't working there must be something wrong in the system
#12 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 13 February 2014 - 08:57 AM
I generally find mini handbrakes good, enough to do a handbrake parallel park ;)
#13 mini-geek
mini-geek
  • 1,169 posts
Posted 13 February 2014 - 09:13 AM
A quick stab of the brakes as you pull the hand break helps lock the wheels..
#14 Alex_B
Alex_B
  • 4,573 posts
Posted 13 February 2014 - 10:47 AM
I need to perfect my handbrake turns then! only seem to manage it on gravel and thats no good, the ladiez dont like going on gravel only car parks and that is the point of a handbrake turn is it not ? ;)
as above really, the mini handbrake is actually quite good if in good service so just work your way through the system, check and adjust anything that looks iffy and make sure your back brakes are adjusted correctly while you are there and it should pass no issues
I am pretty sure you can get a fly off handbrake kit from minispares incidentally if you wanted that for "rallying"
#15 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 13 February 2014 - 12:57 PM
or i can sell you a bit of tape to stick over the button for £5
